Heritage softail fouling plugs
Old Oct 2, 2023 | 06:59 PM
Boleshh48's Avatar
Boleshh48
2nd Gear
Default Heritage softail fouling plugs
Hello, I have a 2010 heritage softail classic. Bike was running great and never had an issue until I touched it. I replaced the battery as it was over ten years old. Also replaced the grips. Rode the bike for about an hour. Next day started it up and it misfired through the intake. Started it again and it ran and sounded good for almost 2 hours. After the bike cooled off I pulled the plugs and they were carbon fouled (dry) but did smell like gas. On my first trip I did fill the bike up with 93 octane from a gas station that I've used before. My question would be could any of these things I did cause this to happen? Bad gas, battery pulled so something with the brains of the bike? Or grips? I was sure to follow the service manual for the grips and have them set to spec. Thanks guys any advice is appreciated.
Old Oct 2, 2023 | 07:08 PM
brakeless's Avatar
brakeless
Doubtful just doing what you did would cause that. Maybe some collateral damage? Something got knocked loose when changing the battery maybe? Go back and just give it a good look. Bad gas? Maybe. Drain it and replace it if you think that's a possibility. Otherwise may be just coincidence something failed when it did. Can you check for codes?
Old Oct 2, 2023 | 07:16 PM
jkinner's Avatar
jkinner
If its still running good I would just put a new set of plugs and ride. I change mine every 10k or so (16 Deluxe) to me cheap maintenance item. JMHO, Ride safe.
Old Oct 2, 2023 | 07:34 PM
Boleshh48's Avatar
Boleshh48
2nd Gear
I did forget to mention in my rambling that the plugs were changed less than 500 miles ago. I'm really not sure how to check codes. Do I need a scan tool for that? I will give it a second look tomorrow if all else fails I will take it to my indy to check it out.
Old Oct 2, 2023 | 07:36 PM
Boleshh48's Avatar
Boleshh48
2nd Gear
I did forget to mention the plugs were put in less than 500 miles ago. I'm hoping it's a gas issue and not something else. Would it hurt to run some seafoam through it?
Old Oct 2, 2023 | 07:39 PM
brakeless's Avatar
brakeless
Here's a link to read on how to check codes. Are the plugs the correct one's?
https://www.uti.edu/blog/motorcycle/trouble-codes
Old Oct 2, 2023 | 07:43 PM
Boleshh48's Avatar
Boleshh48
2nd Gear
Awesome. Thanks for that link. Yes they are oem plugs and gapped to .37. I never believed in using anything else.
Old Oct 2, 2023 | 07:49 PM
brakeless's Avatar
brakeless
Remember, YouTube and the Inet are your friend. Tons of how to stuff on there. Just use your discretion in which one's to believe. There are some idiots posting there.
Old Oct 4, 2023 | 12:16 PM
hattitude's Avatar
hattitude
As brakeless suggested, check for codes.... it could point you in the right direction to start your diagnosis...
It has been my experience that when an issue arises soon after I did some work on a bike, the issue was caused by something I "fixed", moved, touched, or bumped when I did my work.
Barring a code pointing you in a certain direction, start with checking your previous work... I'm fairly meticulous when I work on my bikes... and yet I've made a couple big, stupid mistakes in my day.... No, I'm not going to share them...
When you replaced the battery, what connectors/cables did you have to handle and/or move? Check those connections and make sure they are clean & tight... both ends of the cables.
When you changed grips, did you remove the switchpaks.....?? Very easy to pinch a wire, or bump a connector leading to a bad connection. Check the wires/connections to any switchpak you had to move/remove...
Of course, it is possible that it's a coincidence that something failed just after you did some other work, so keep an open mind as you do your diagnosis...
Keep us posted on your progress....
Old Oct 5, 2023 | 05:58 PM
Boleshh48's Avatar
Boleshh48
2nd Gear
Thank you for the good advice. I checked over everything I did and it all looked correct. I called my indy yesterday and spoke with them about it and they suggested I replace plugs and wires. its going to sound a little crazy but it really woke my bike up. It sounds better and feels smoother on acceleration. I used to run autolites but changed to champion copper plugs. I put on a set of 10mm screamin eagle wires. I'm optimistic that it was the stock wires were not sending good power to the plugs. I put on about 100 miles today, I am going to put some more miles on the bike and then check them. I will keep you guys posted!
Oakers3
General Topics/Tech Tips
Nov 29, 2022 06:48 PM
IRON1250
EVO
Apr 17, 2017 12:43 PM
Mjc5492
Jun 9, 2015 01:59 AM
Ratbike_Mike
Aug 20, 2014 11:30 AM
Mal74
Feb 28, 2011 07:53 PM
