09 Fatboy - Crank- no Start. Stumped
Old Oct 10, 2023 | 02:57 PM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by slc123
thank you- will do.
yes, hit it with starting fluid, no dice.
You have assured me it has good spark and you are getting starter spray into intake.
So get it warmed up first start in the morning when you say it runs good. Turn it off. Let it sit and see if it restarts. If it doesn't, pull plugs and see if there so wet, it won't fire ..
​​​​​​if not wet, might consider replacing temperature sensor in throttle body. However, if that's the problem, it should still pop on starter fluid.
FIL_05
Sep 19, 2020 03:24 PM
troygalloway
Sep 18, 2016 09:57 PM
Mugsy666
Aug 3, 2016 08:19 PM
welder1027
Apr 4, 2016 05:32 AM
Tribe of Judah MM
Jun 20, 2012 10:25 AM
