2002 Fatboy Engine light comes on.
Old Dec 6, 2023 | 02:19 PM
DieselHaphazard's Avatar
DieselHaphazard
6th Gear
Default 2002 Fatboy Engine light comes on.
2002 Fatboy injected.
After riding the bike for about 5 minutes, the red engine light will come on in the speedometer.
If I shut the bike down and start it back up, the engine light is out.
So, the trip button code reading trick won't work for this.
I've already tried it and there are no codes stored.
No loss in power or any other adverse symptoms. Just a red engine light after driving for 5 minutes...
I ordered a 4 pin to 16 pin diag connector adapter to try and read it that way.
I don't get any power to my code reader from the bike. Related to engine light issue maybe??
Any help is greatly appreciated!!
Thanks for looking!
Old Dec 6, 2023 | 02:51 PM
hattitude's Avatar
hattitude
Thanks for looking!
It may be only throwing an active code after the bike warms up.....
Does it show a Historical code?
The engine light will light until the bike is started...
If it goes off, and stays off, you have no DTC codes....
If it goes off, then a few seconds later it comes back on, only for several seconds, and goes off again.... it's telling you that you have a historical code in the ECM...
The speedometer check on older bikes only gets Speedo & TSSM codes. To get engine diagnostic codes, you need to do another procedure, if you don't have the Harley Scanalyzer (an older dealer tool)...
I don't remember it off the top of my head, but it involves running a jumper wire between two of the pins in the diagnostic connector, then counting the flashes....
The procedure should be on this forum if you search for it, and it is in the Factory Electrical Diagnostic Manual, and I believe it may alos be in the Factory Service Manual...
I think a couple of the higher priced diagnostic tools, like the Techno-Research Centurion and Diag4bikes can read/clear those older ECM codes... but my cheaper Daytona Twin Tec, Twin Scan IV, only works on newer BCM bikes...
Old Dec 6, 2023 | 02:55 PM
DieselHaphazard
6th Gear
Thanks. I'll look for the jumper trick and try that. The light comes on and goes out when I turn the ignition to ON.
So, I don't think there are any historical codes in it. I just need a way to read it while the light is on.
Old Dec 6, 2023 | 03:19 PM
Jackie Paper's Avatar
Jackie Paper
Thanks for looking!
Only the last few years of Harley will work with OB2 with the adapter if that is what you are saying. The oil light is also red. That won't store a code. To read codes, the bike must be off and to get too it bike needs to be turned off.
Old Dec 6, 2023 | 03:43 PM
cobra23's Avatar
cobra23
Have you changed to non stock spark plug wires recently? This could cause a check engine light without codes
Old Dec 6, 2023 | 03:51 PM
DieselHaphazard
6th Gear
I've had the same Screamin Eagle wires on there for a while now. I don't remember when I put them on.
But, it's been running fine with no lights up until a few weeks ago.
Maybe it's time to change them?
Old Dec 6, 2023 | 06:16 PM
cobra23's Avatar
cobra23
Couldn't hurt. I had a 2003 fatboy and put on the screaming eagle plug wires. When I got the check engine light I took it in and the service manager told me the light came on " because I tried to start the bike with no spark plug wires." I told him he was an idiot. It was when I took the bike to get dynoed at a different dealer that the tech told me about the spark plug wires
Old Dec 7, 2023 | 08:52 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
The manual has the jumper procedure but I think it is in the Electrical manual. Don't remember for sure, but I did it before having my ECM reflashed. Let me know if you can't find it and I will look it up for you.
Old Apr 15, 2024 | 12:16 PM
DieselHaphazard
6th Gear
Finally got the codes out of the ECM.
P0373 Crankshaft position sensor circuit intermittent
P0605 ECM flash error
P0261 Front fuel injector open/low
P0263 Rear fuel injector open/low
I replaced the crank sensor with a new one from the dealer. That fixed that code.
After thinking about it for a while, I gave in and bought a Dynojet Power Vision Black.
I talked with the guys at Fuel Moto and another guy at Dynojet before I flashed the bike.
Scott at Dynojet came up with a custom OEM tune for me to start off with.
Loaded that tune into the bike and ran it around the block. The bike didn't run that great. But, it ran and the engine light stayed off.
Got back home and loaded the Fuel Moto tune into the bike. What a difference!! Bike runs like a raped ape!!! And, the engine light is still out!!!
Extremely happy with how this turned out!!!
bullin82
General Topics/Tech Tips
Jul 6, 2017 01:13 PM
mclldavidson
Aug 14, 2015 03:57 PM
Rogersarge
Apr 8, 2015 08:07 AM
n2narcosis
Jul 9, 2012 12:28 AM
00 fatboy
Feb 28, 2007 01:38 AM
