Fuel gauge reads low 2005
Old Mar 25, 2024 | 10:16 AM
Wakko47's Avatar
Wakko47
Default Fuel gauge reads low 2005
Bike sat for years, replaced all of the internals in the tank, including sending unit. The fuel gauge now reads low, and will trip the light while there’s still 1.5-2 gallons in the tank. I know the gauge is resistance based, is there a known bottleneck connector that could be the culprit?
Old Mar 25, 2024 | 04:20 PM
hattitude's Avatar
hattitude
Is it carb or EFI.....By "replaced all of the internals in the tank, including sending unit" sounds like we are talking EFI, but you don't say for sure... Even the carb bikes have (internals) and a sending unit in the tank....
Anyways, if you removed the tank for the internal parts repair, there is a connector on the left side (primary side) of the tank, along the top frame backbone. The fuel gauge wires run through a tube in the tank, out the bottom at the left front, and connect to the bike's harness at the above mentioned connector....Those connector pins can get bent, leading to improper contact and cause a bunch of fuel gauge issues. I found that out the hard way...
If that connector was handled (removed, pushed, pulled, or prodded) during the replacement of tank internals, I'd check that connector first... it's free.
The only other thing that pops into my mind, is both Carb & EFI sending units have a float, at the end of an arm. As it moves up & down with the fuel level, it sends signals to the gauge on the tank volume. If the gauge is working properly, except for it is not accurately and consistently reporting low volume, that float arm may have been bent during installation.
Good luck with your diagnosis and keep us posted
Old Mar 25, 2024 | 04:26 PM
duffy8540's Avatar
duffy8540
I upgraded the speedo on my 05' to a speedo/tach combo that has a fuel gauge there as well as the one on the tank cap. The cap gauge is accurate but the gauge tach always shows 1/8 of a tank low. It irritated me so I just turned off the speedo gauge and use the cap one in combination with the odometer.
Old Mar 25, 2024 | 08:14 PM
back again's Avatar
back again
I haven’t had a fuel gauge since a month after I bought my 05 Train. After several trials I ended up using trip meter at fill up with stock motor at 160 miles and never ran out of gas. Close enough for me.Bigger motor now I fill at 150 miles. I very rarely run thru a tank steady riding.
Old Mar 25, 2024 | 09:44 PM
hattitude's Avatar
hattitude
I never owned one of those Speedo/Tach combos. It could very well be my old man memory, but I thought I read once there was a calibration procedure for the fuel gauge portion.... If you still have the install instructions, you may want to give them a quick scan...
If my memory is wrong on that... sorry for wasting your time
Old Mar 26, 2024 | 03:33 PM
Wakko47's Avatar
Wakko47
Well, I sold the bike before fixing the problem. I explained to the new owner about the plug that Hattitude mentioned, but I'm not sure he really got it or not. He's over three hours away, rode the bike home, so I won't be able to help him fix it.
Old Mar 27, 2024 | 08:42 AM
Clammy's Avatar
Clammy
I had a similar issue with Reaper (2005 Night Train). I fixed it by bending the floater arm, that hangs off the sending unit, until it read correctly. Even then, I still use my Trip B odometer as my fuel gauge, and fill up around 180 - 190 miles (if I'm running steady highway speed).
Cheers!
Old Mar 27, 2024 | 09:16 AM
04FXDI's Avatar
04FXDI
Yea I haven't a fuel gauge on my 05 Heritage since I bought her. I do the same as @Clammy
Old Mar 27, 2024 | 01:01 PM
byersmtrco's Avatar
byersmtrco
My 03 has read low since day one. When it's close to the E and the low fuel light
comes on, it will take 3.5 gal (aprox)
I also use my trip meter every time I fill up. I figure on 35 mpg, so I usually fuel
at 140 mi.
Old Mar 27, 2024 | 02:22 PM
duffy8540's Avatar
duffy8540
It does have a cal section, I did it twice and came up with the same thing. According to HD this combo gauge may not have all functions active on an 05' and the ones it does have (except for speedo/odo) may not be accurate. I believe it was designed to work with 06' and up Touring bikes. I didn't have much choice as my speedo was bad and they no longer made it's direct replacement except for the combo gauge. Such is life with an older bike.
