Breakout Tire Wear / Leaning Issue
Old May 10, 2024 | 01:09 PM
NuttyKev's Avatar
NuttyKev
Default Breakout Tire Wear / Leaning Issue
I have a 2018 Breakout that I always feel like Im leaning to the right. It was confirmed when I noticed the rear tire getting bald on the right side and someone behind me asking why I was always leaning to the right. This isnt my first bike, and I also currently have a road glide. Ive never had a leaning issue before on any bike and I don't on my current Road Glide. My first thought was maybe the tire alignment was off. As far as I can tell, It looks dead on, with using the softail alignment tool. Any thought on what would cause this?
Old May 10, 2024 | 02:46 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
It may be you. For whatever reason, I tend to lean a bit to the left on a bike. No, it's not from sitting on my wallet.
Old May 13, 2024 | 09:03 AM
slonez_sg's Avatar
slonez_sg
I have heard of a opposite story. Bike lean to left becos owner replace stock exhaust system with an aftermarket significant lighter system.
Old May 13, 2024 | 10:30 AM
jake24lt's Avatar
jake24lt
The crown of the road might be the issue. Having a narrow tire probably doesn't show as much as the big *** tire on your bike.
I will add this: https://ridermagazine.com/2018/04/30...ycle-handling/
Old May 13, 2024 | 10:51 AM
NuttyKev's Avatar
NuttyKev
The problem with the crown of the road theory is that should make the left side of the tire wear faster. But the right side on my bike is wearing faster.
Old May 13, 2024 | 10:59 AM
John Harper's Avatar
John Harper
Coriolis effect based on your current latitude?
John
Old May 13, 2024 | 11:16 AM
jake24lt's Avatar
jake24lt
found this thread from a while back, might help.
https://www.hdforums.com/forum/softa...l-crooked.html
Old May 13, 2024 | 11:56 AM
NuttyKev's Avatar
NuttyKev
Thanks, that thread explained exactly whats happening to mine. Basically, I put a much lighter 2-1 exhaust on, making the left side of the bike heavier and naturally leaning to the left, so to compensate, and make the bike go straight down the road, Im forced to lean it to the right.
Old May 14, 2024 | 04:08 AM
fugawi's Avatar
fugawi
simple as this. you rear tire is out of alignment or your frame is bent and the steering neck is not parallel with the ground..
I call bullshit on different exhaust. that is a stupid theory...
Old May 14, 2024 | 04:31 AM
strokelessone's Avatar
strokelessone
I guess it can happen, but you would think every touring bike would be leaning to the left due to the weight of the primary hanging off the side, but just my opinion...lol. I did see a video (which I cant find) about front forks not being set up properly that may cause this as well
NCTim
Jun 2, 2023 09:48 AM
Shanewabindato
Wheels/Tires
Oct 20, 2020 06:33 AM
CSS899
Jul 13, 2020 10:35 PM
mmancuso
Nov 8, 2012 12:01 PM
giveithell03
Wheels/Tires
Jul 8, 2010 07:55 PM
