Front fender removal
Old Aug 31, 2007 | 03:36 AM
kjunguy's Avatar
kjunguy
Default Front fender removal
A friend asked me to help him remove his front fender on his 05 springer. He wants to have it custom painted. Any special tricks on removing? Special tools? Thanks.
Old Aug 31, 2007 | 08:03 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: Front fender removal
On the Heritage model I believe that you have to remove the axle to get it off. The 21" skinny tired version is a bit easier that way with just the usual 4 bolts (I think).
GADave's Avatar
GADave
No big deal, no special tools. Much easier if you get the front end off the ground with a lift cause you'll probably have to remove the front wheel.
If it has a front fender light you'll have to take the pins out of the plug to get 'em through the hole in the side of the fender. Use a piece of stiff wire or a small jewler's screwdriver as a pick. When you look in the end of the plug there are small holes in there - stick your pick in one of the holes and wiggle it until you can pull the pins, it can be a PITA to get the hang of but the combination is there, just have patience.
Dave
RKC1965
2014-2024 Touring Models
Sep 12, 2016 07:25 AM
hoethree
Dec 1, 2011 06:43 PM
English Pete
Jan 29, 2010 05:31 PM
Blazer
Jul 14, 2005 06:32 PM
orpy
Jan 20, 2005 07:17 PM
