04 Fatboy Bogging on hard trottle
Dave Adams
Dave Adams
The clues in your description would seem to be that it sat for a year. That could negatively affect the fuel system.
Who did the carb rebuild?
It is possible to just swap out carb parts and leave some hard deposits/gunk in the pathways/channels of the carb. I know a few people who will strip a carb body bare, then put it in an ultrasonic cleaner to get all the hard gunk/deposits out when rebuilding a carb... especially if it was old, and/or sat for awhile..
Who tuned it?
Was the OEM EPA plug removed from the carb to allow access to the mixture screw? Changing jets without adjusting the mixture screw won't work well...
There is a process for tuning the CV40 carb. It involves adjusting the mixture screw, then letting the performance tell you if you need a pilot, main jet, or needle change. But the process always begins and ends with the mixture screw. Having owned and replace a couple Keihin Butterfly carbs on my shovel heads, I am a fan of the Keihin CV40.
Here's a good site for instructions, guides, and parts on the CV40 carb:
https://cv-performance.com/instructions-guides
If it were my bike, I would go through the fuel system start to finish.
I would start with checking the tank to make sure there is no peeled lining material or other debris flosting around that can block the petcock.
If you still have the OEM vacuum petcock, I would inspect, rebuild, and/or replace that.
I would check the fuel line from the tank to the carb for interior delamination that could affect fuel flow. Maybe just replace that section of hose as maintenance. (use 1/4" I.D x 5/8" O.D. premium fuel line)
I'd revisit the carb rebuild. Checking for missed blockages in the passageways and pay specific attention to how the float was set.
Then I would give a tune...
Not being there to put hands on and hear for myself, that's about all I can offer at this point..
Keep us posted....
Regards,
Dave Adams
1. Need to revisit the carb and the accelerator pump parts to ensure all passages are clear & clear.
2. Make sure all rods and mechanisms are functioning correctly and all the parts are in the correct locations.
3. Make sure the accelerator jet nozzle is facing the correct direction and is squirting fuel when the throttle is twisted.
4. With the air filter off, petcock on, the carb charged with fuel, and the engine turned off, you should be able to see fuel squirt into the carb throat when the throttle is twisted.
5. Make sure the vacuum slide is operating correctly, you should be able to push it up with your finger and not feel any sticking and then letting it go it should smoothly return to bottom.
If it's rapid acceleration from a stop or low speeds then CoolBreeze3646 has some good suggestions. If it bog on WOT at higher speeds or under demand when fuel requirements are highest, then I'd suspect not enough fuel flow to meet the demand.
I believe there is a strainer in the tank at the petcock hole. You can remove the screen when the petcock is removed. But older ones can be difficult to remove in one piece because the plastic breaks down over time. If there is an inline (in the fuel line) filter, I'd likely remove it or replace it with a new filter. And as hattitude suggested, look closely at the petcock itself. If it is vacuum controlled, I'd replace it with a good quality manual petcock.
Paul
Dave Adams
Seriously though, it sounds like accelerator pump or fuel inlet, is the float set correctly?
If you have a weak spark due to a bad coil it can bog when you open the throttle.
Dave Adams
Just FWIW...
The CV40 carb has both an accelerator pump and a vacuum slide....
It's easy to mix up the terms if you are not familiar with the CARB.
