Good Morning
I'm making my way through my new bike and it has about 22k miles on it. I have a few questions about oils:
Should I change the fork oil? I picked up some 20wt fork oil from the local moto shop - is that correct for this bike? Sorry, I don't have a manual...
I did the 3 plug oil change and the engine and primary oils were NASTY. Should I change them again as a flush?
Any input would be great. Thanks!
Andy
You need to get a factory HD service manual with all the necessary information needed to complete this task correctly. If you over fill the oil level, you will likely damage the oil seals. If you underfill the oil level, it will affect handling.
