internal bearing fail
Old Jun 28, 2025 | 06:11 PM
  #71
hattitude's Avatar
hattitude
I went through and reread this post.. Setting up my ignore list makes it much more readable.. Did you ever pull the primary drive off? Some of the 03 and up to the 6 speed TCs had an issue with stack up error on the drive side crank. The crank nut bottoms out on the crank splines before adequate clamping pressure is achieved on the alt rotor and comp. What you may be hearing is rotor ratting on the crank. Might be worthwhile to remove the comp and check the splines on the rotor, if not bad, trim 0.060 off the base of the nut and reassemble. You can follow the torque procedure provided in the above bulletin.. All you need is for tools is a jam bar, 1 1/2 socket, 1 3/16 socket and tq wrench. The Jam bar can be made from a 1x1/4 aluminum about 8 inches long.
blackjeep mentioned a possible loose compensator bolt back in Post #35.
Then in post #36, I attached TT122, that explains the stack-up issue and a fix.
I also mentioned and posted the Service Bulletin for the change in the torque spec/procedure.....
They kind of got lost in the following "noise"....
Old Jun 28, 2025 | 06:24 PM
  #72
blackjeep's Avatar
blackjeep
Pretty yucky thread. Noise is right!
Old Jun 28, 2025 | 06:51 PM
  #73
Max Headflow's Avatar
Max Headflow
Yeah I didn't read TT122 thought it was part of the next one.. That is really the first step.. Thought it was part of M-1170 which I know so I skipped reading the bulletin.
Anyway it's the first thing that should be done. The filter thing is good but it's good to do occasionally anyway. IMO better than sending oil off to be analyzed.
Old Jun 28, 2025 | 07:47 PM
  #74
Cap77's Avatar
Cap77
Originally Posted by Rounders
But would have been a huge mess that way.
Having it in vice kept everything secure too.
LOL
what mess?
do you see any mess in the pics?
That's just the way it came apart
I was joking when I suggested you turn the filter "hole side down" to drain.
maybe I shouldn't have been
Want's funny now, I show you a simpler, easier way and you choose to blow bubbles out your butt
KTF
Old Jun 28, 2025 | 08:05 PM
  #75
Cap77's Avatar
Cap77
I'm not sure what my largest sockets are.
I may have wrenches up to 1 3/16, but unlikely sockets
just looked, biggest I have 1 1/4 wrench
I'll pull the cover tomorrow.
.I have a cresant that will open to 1.5" to see if nut is loose
if not loose, can I run the bike with cover off and stethoscope around for a minute or so?
KTF
Old Jun 28, 2025 | 08:40 PM
  #76
Tommy C's Avatar
Tommy C
Cap, you can buy the individual sockets you need to do the job on Amazon or Ebay. If you are on a budget there is no reason to buy a one inch or 3/4 drive complete socket set.
Old Jun 28, 2025 | 10:13 PM
  #77
Max Headflow
KTF
The nut may not be loose.. It may simply be bottomed.. You can give it a try but don't round off the nut. It's kind of thin.
You don't want wrenches. You need sockets.. The 1 3/16 need to be reasonably thin wall as it has to go into the clutch hub. The 1 1/2 is on the end of the crank and is going to be torqued to over 150 ft-lb. Break away is going to be even higher. You will need a reasonable breaker bar.. Also an internal snap ring plier. You should be able to get the 1 3/16 from lowes or home depot of Oreillys
Old Jun 28, 2025 | 11:03 PM
  #78
Rounders's Avatar
Rounders
KTF[/QUOTE]
I wasn't born with big sockets
LOL
what mess?
KTF
As I said my filter was about half full of oil
Old Jun 29, 2025 | 07:29 AM
  #79
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
That's good the filter was so clean - That's very good. You'll find the issue, and at least it's not self-destructing something presently.
That filter cutting tool has my interest now. I may have to add one to the tools.
Old Jun 29, 2025 | 08:17 AM
  #80
Cap77's Avatar
Cap77
if you don't hate Mr Bezos, here's the best buy of this type
Amazon.com: GEAROLL 77750 Oil Filter Cutter Tool with Vise Jaw Plate, Oil Filter Cutter Cutting Tool for Filter Cutting Range 2-3/8" to 5" : Automotive Amazon.com: GEAROLL 77750 Oil Filter Cutter Tool with Vise Jaw Plate, Oil Filter Cutter Cutting Tool for Filter Cutting Range 2-3/8" to 5" : Automotive
Mine works more than fine
KTF
