Rear quick detach kit?
Old Mar 11, 2026 | 02:32 PM
Patrick_75's Avatar
Patrick_75
Default Rear quick detach kit?
I have a 2016 flss and am playing hell trying to find a quick detach kit for the sissy bar any suggestions thank you
Old Mar 11, 2026 | 02:46 PM
Patrick_75's Avatar
Patrick_75
Old Mar 12, 2026 | 05:45 AM
bustergut's Avatar
bustergut
From catalog 2017 Harley-Davidson Genuine Motor Parts + Accessories.
Old Mar 12, 2026 | 06:51 AM
WKNDS's Avatar
WKNDS
The Forge LLC has a few listed at the bottom of the page;
https://www.theforgellc.com/softail/2011-2017-fxs-fls/
They are going to use the same attachment points as your
rack, so you'll only be able to use one or the other at a given time.
I welded tabs onto my QD sissybar so I could run the HD Aero Rack.
hth,
T.
Old Mar 12, 2026 | 07:03 AM
bustergut's Avatar
bustergut
I see there are two similar threads - this one was started 14mins before the other one.
Old Mar 12, 2026 | 07:04 AM
bustergut's Avatar
bustergut
I see there are two similar threads - this one was started 14mins after the other one.
Old Mar 12, 2026 | 07:05 AM
WKNDS's Avatar
WKNDS
I responded to your "other" thread with the same name, but you did not
include the same pictures in it. The rear fender does not appear to
be an original Slim fender. If the struts & fender were changed to
run those hardbags, you will need to find a sissybar/rack combo
that matches the fender strut attachment points. They will be
different than those on the stock FLS/FLSS fender.
good luck,
T.
Old Mar 12, 2026 | 07:11 AM
WKNDS's Avatar
WKNDS
Yeah thanks, just noticed it too. I was replying from the daily "summary" email & not
looking at the actual forum....
T.
Old Mar 13, 2026 | 05:09 AM
Patrick_75's Avatar
Patrick_75
I ordered the harley davidson docking gear it looks like the original strut. thank u I will let u know what happens.. all I can find for sissy bars are the skinny tubing? Any idea for that.. I would like the same diameter tubing as handlebars
Old Mar 13, 2026 | 05:28 AM
2goldens's Avatar
2goldens
good luck,
T.
Seeing how the threads were same date, same topic by the same poster I merged them to avoid confusion.
