proper jetting
Old Dec 7, 2005 | 05:27 PM
harleylightweight's Avatar
harleylightweight
Default proper jetting
Hi , Can someone tell me the proper jet size that should be used on a some what stock evo.By some what stock I mean it has drag pipes and an S&S breather . The bike is a 1989 FXST Thanks, Bernie
Old Dec 7, 2005 | 05:50 PM
HDF Tech's Avatar
HDF Tech
Default RE: proper jetting
You would probably do good upping the low speed to about a 44-45 from the stock 42 and the high speed to something in the area of 175-180 . You'll find the stock jetting in the carb section of the factory manual. There are expensive ways and kits like different needles and jet kits that have parts you don't even use to do this, but the upsizing of the jets and possibly shimming of the needle would get you in about the same area for much less $$$ Probably about $6-$8 total.
This link https://www.hdforums.com/m_65123/tm.htm is for the TC88 but with the exception of jet sizes still applies to your CV carb.
The stock jetting for that bike would be in the 42/ 160 area from the factory. You should consider replacement of the drag pipes to get the bike to run better. They are not conducive to making power on anything but the top end. Here's a link to a how to make the drag pipes more efficient https://www.hdforums.com/m_79533/tm.htm
MIKE93SVT
EVO
16
Jun 26, 2016 11:13 PM
Huggerbugger
May 4, 2016 10:37 PM
tspierce
EVO
Mar 10, 2010 10:12 PM
asm481
Exhaust System Topics
May 16, 2009 07:32 PM
redrum
May 24, 2008 07:44 PM
