brake light trouble
Old Nov 10, 2007 | 11:39 PM
adazol7's Avatar
adazol7
Stage I
Default brake light trouble
put beach barson an 07 springer, internally, everything works but the brake light. the light turns on but doesn't work when braking. any help would be great, thanks.
Old Nov 10, 2007 | 11:53 PM
Sanford's Avatar
Sanford
Default RE: brake light trouble
Did you replace the small retaining clip that holds the switch? It's the small piece of copper that's bent double over and acts as a small spring that holds the brake light swithch in place.
Old Nov 11, 2007 | 09:00 AM
kruzin's Avatar
kruzin
My guess is the plunger is broken on the handle bar switch. What you are seeing is the brake light on. This is common to break the little plunger tab off the end of the switch.
iltbone1
Sep 19, 2011 12:18 PM
msuheritage
Jun 23, 2011 06:28 PM
Fat_06
Aug 9, 2008 08:55 PM
cnewty
Jun 23, 2007 01:29 AM
SIDEWAYZ50
May 23, 2006 08:32 PM
