Wild 1 Chubbys
Old Feb 19, 2006 | 10:34 AM
Randcoll's Avatar
Randcoll
Default RE: Wild 1 Chubbys
How much longer would the idle and throttle cables need to be with 508's on a Softail Deluxe? Randy
Old Feb 20, 2006 | 09:57 AM
lp's Avatar
lp
I got the 518's. At 5'9" they were the ones recommended to me by Wild1. They were not wrong. Simply awesome.
Tip: I installed 4" over thottle cables based on wild1's recommendation. They are a little long. I recommend only 2" over, that way all the excess cable is not all jammed up against the inside of your forks. They rub pretty bad and it wont be long I'll be replacing them. I wish I could remember the length of the brake and clutch cables I bought, but whatever they recommeded is what I chose. The brake line was a little short, maybe go with an inch or two longer so you can route it though the factory locations. The clutch cable length was fine. I'd have pictures but my digital cam is broke. Time to spend some of that tax refund...
Hope this helps,
lp
Old Feb 20, 2006 | 10:04 AM
HDF Tech's Avatar
HDF Tech
ORIGINAL: dgb
I just bougth a 2006 FLSTCI. I am new to riding, but I want to switch out the factory handlebars to Wild 1 Chubbys. I am 5'10" and cannot decide between the 508's and the 518's. Which would be better for me on my Heritage in terms on comfort, control and styling. thanks...
Here's a link that will give you an idea how they look, there's a virtual section where you can change the bars... https://www.hdforums.com/m_112517/tm.htm
Old Mar 17, 2006 | 03:17 PM
SoCalFXSTI's Avatar
SoCalFXSTI
Ive had the Wild 1 Chubby "knucklebars" and switched to the "beach bars."
Both look awesome. I am shorter so the beach bars provide more comfort since they are pulled back more.
Old Mar 17, 2006 | 03:24 PM
SoCalFXSTI's Avatar
SoCalFXSTI
My pics didnt post in that last one.
[IMG]local://upfiles/3061/A9381DBBE27B43A08E4A2C3EBC2FA4A4.jpg[/IMG]
[IMG]local://upfiles/3061/24CB0CB8C2924CE4B9361A3777444463.jpg[/IMG]
Old Mar 18, 2006 | 07:14 PM
RoadRunner1's Avatar
RoadRunner1
Randy I just finished my 05 Deluxe. Put on 508's went 4 " over on the throttle and idle cable. Tried 4" over on clutch, way to long. I left the stock clutch cable on while I decided what to do. I bought a stock length Clutch cable in braided SS and it work just fine. You could fine an aftermarket that is 1" longer not that much difference. The SS brake hose was 49" The bar look great.
Old Mar 18, 2006 | 08:59 PM
vulhalla's Avatar
vulhalla
I just went and got mine back. An o3 Heritage that I had 10" apes with braided cables and internal wiring. also bought the leather tourpak. after I wash it and get that on Ill post a pic. Just to cold to wash now, just got it back out last week but the weather has turned a little nippy again, But I love the bars, very comfortable and the wrist are at alot better angle
CJinNH
Apr 13, 2017 09:52 PM
Shwaig
Mar 28, 2014 10:22 AM
hinerj
May 24, 2011 12:51 PM
conroskie
Mar 17, 2008 10:17 AM
jrudicel
Jul 13, 2006 02:51 PM
