Replacing oil tank...any advice?
Old Feb 10, 2008 | 07:14 AM
mojojones's Avatar
mojojones
Default RE: Replacing oil tank...any advice?
ORIGINAL: monkyman
Looks great! I've often considered changing out the oil tank on my Train, and like you, I have the chrome trans cover that needs to go on as well.
BTW, I have the stud rear lowering kit on mine, I don't have it slammed as low as it will go, but i've ridden two up with 450lbs between the 2 of us and never bottomed out.
How have you got the shock preload set? Is it stiff under normal conditions?
Old Feb 10, 2008 | 08:46 AM
monkyman's Avatar
monkyman
I used this kit: http://www.jpcycles.com/productgroup...ley&page=1
I left the shock preset where it was when I bought it, not sure what setting it is on. It is a little stiffer that it was before the kit, but not too bad. I just lift my butt off the seat when I see a pothole coming.
Old Feb 10, 2008 | 11:43 AM
mojojones's Avatar
mojojones
ORIGINAL: monkyman
I'm all about saving $$$.........but I've heard that when you get 'em slammed with the bolts, you can get your fillings jarred out by a cigarette butt.......I don't mind spending the $$$ if the difference in ride quality is worth all the bones for the shocks
eastcoastink
Sep 21, 2013 10:02 AM
Hitechluddite
May 14, 2012 01:05 PM
vgfxst05
Jul 22, 2010 03:19 PM
WVNightrain Rider
Oct 24, 2009 06:54 PM
niczumbo
Nov 10, 2007 05:47 PM
