eBay Bag Score
Would you do us a favor and let us know how it really holds up to the description when it arrives?! Some feedback, if you will? I like it!
[align=left][/align]
Quality: Leather is thick, finish is excellent.
Neat details: The inside back has a leather pocket sewn in. It doubles the thickness of the back, and the pocket would hold a baggie with some paperwork in it, or even some thicker stuff. Pocke also has a small leather patch with the maker's name branded in it.
Concerns: Stitching doesn't appear that substantial, but I won't know how it holds up 'til after I get some use out of it. If it turns out to be too weak I will rivet the stress points.
It'll be a couple months before it gets on the Sloptail. I have it torn down to almost parade rest for some customizing: new rear fender with Nightster side-mount plate, bullets for tail/brake/turn lights; smaller battery to allow solo seat to sit lower; custom made solo seat pan I'll be adding leather to; new engine & carb; paint frame, tanks rear fender; custom hidden mount trees; front & rear brakes operated off handlebar master cylinder, with rear coming off a proportioning valve; outer primary cut open more than it is already; taller risers; completely rewired using WW2 Navy fighter plane aircraft warning light switch box.
[sm=ttiwwp.gif]
Let's see it on.
As a AF retiree, it looks like the perfect place to stash the orange vest.
