Removing headlight bulb, need help
Old Mar 21, 2008 | 01:34 PM
jlevin75's Avatar
jlevin75
Default Removing headlight bulb, need help
Hey everyone, newbie here. I'm installing the aux lights on my '07 softail custom and I need to get into the headlight assembly to connect the wires. I've pulled out the scre on the bottom of the light but the ring won't budge. The owner's manual has instructions for every other light but the headlight. Am I missing something or do I just need to put some more strength into it? Any help would be appreciated!
Old Mar 21, 2008 | 01:57 PM
BigMike17's Avatar
BigMike17
Default RE: Removing headlight bulb, need help
The ring is held on, within the upper inside lip, by two pieces that stick up a bit which are covered with rubber. You just need to pull the bottom out and push up at the same time. Good luck with it.
Old Mar 21, 2008 | 02:33 PM
fbhawg's Avatar
fbhawg
Don't lose the rubber!
Old Mar 22, 2008 | 11:11 PM
Harley03joe's Avatar
Harley03joe
Right What BIG MIKE SAID ,,, As Far As Loosening The Rubber, If You Do
Just Cut Off A Small Piece Of Thin Vacuum Line
Figstr
Nov 7, 2011 04:15 PM
HarleyNoob77
Oct 8, 2011 07:55 PM
jcmusic
Jun 17, 2010 04:27 PM
Topspin
Oct 9, 2008 04:55 PM
dovesprings250r
Jul 31, 2008 09:26 PM
