turn signal problem
Old Apr 28, 2008 | 02:33 PM
macdon's Avatar
macdon
Stage II
Default turn signal problem
I'm having a hard time diagnosing a turn signal problem.
1993 Fatboy (factory lights)
Blinkers don't work, bulbs are fine. (save the blinker fluid jokes)
If I turn switch toacces: signals work.
If I turn switch to lights, ignition, or bike running: no blinkers.
If I hold down the signal button when blinkers aren't working, I can hear a faint ticking from the ignition switch area (timer?)
If I remove a front bulb and press the signal button the back blinker lights up but no flash.
Its snowing up here today in Wisconsin and I can't ride, but I'd like to fix this before winter's over.
Thanks
Old Apr 28, 2008 | 03:47 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: turn signal problem
Sounds like you might have a burned or bad contact in the ignition switch. Maybe time for a new one.
Hades02
Electrical/Lighting/Alarm
Aug 22, 2019 04:20 AM
sporty63
May 10, 2014 03:07 PM
09xl883l
Sep 11, 2012 10:22 PM
hfdarson1
Aug 7, 2010 11:01 PM
wallybally
Apr 30, 2008 08:29 AM
