95" to 103"
Old May 3, 2008 | 10:17 PM
EXAMMO's Avatar
EXAMMO
Default 95" to 103"
I have the 95" Big Bore II kit and 204 cams. I want to upgrade to the 103". It is my understanding that I only need to switch out the crank for a stroker crank to raise my CI's to 103". Is this true? If so, what crank (part number/manufacturer) do you recommend?
Old May 4, 2008 | 02:17 AM
DocTkd's Avatar
DocTkd
Default RE: 95" to 103"
I believe you have to use shorter pistons also to clear thr longer stroke.
Old May 4, 2008 | 05:35 PM
EXAMMO's Avatar
EXAMMO
Thanks for the reply. That sounds right. Anyone else have any suggestions?
Old May 4, 2008 | 05:43 PM
Pribbz's Avatar
Pribbz
2nd Gear
Sounds Right. But for the money you could make more power with less cubes. Check out Revolution Performance. From my understanding you only pick up a couple hps and lbft with the added stroke.
6165hd
Mar 8, 2008 01:34 AM
cirhere2
Jan 6, 2008 09:29 AM
sugarbear
Exhaust System Topics
Jan 20, 2007 12:05 AM
broke joker
Nov 12, 2006 09:37 AM
blk06rk
Apr 19, 2006 11:52 AM
