Lower belt guard
Old May 7, 2008 | 07:39 PM
j09789's Avatar
j09789
Default Lower belt guard
What's the trick to installing a chrome lower belt guard on a 1997 Softail Fatboy?
Old May 7, 2008 | 08:43 PM
willyp's Avatar
willyp
Default RE: Lower belt guard
Patience
Old May 9, 2008 | 07:11 PM
j09789's Avatar
j09789
I'm thinking that the exhaust pipes on the other side have to come off.
Old May 9, 2008 | 07:23 PM
BlackDragon's Avatar
BlackDragon
Lower belt gaurd is pretty easy.
Usually there is a bolt on the lower left inside that you only have to loosen and can usually get a ring/open end spanner on.
You may need to take the rear splash cover out first if U can't get to the bolt. The splash gaurd has 2 bolts down the bottom and clips in at the top. I use a jack but U can get to it laying on your back.
Once this is done its just a matter of taking the other 2 bolts out holding the lower belt gaurd on and a bit of wiggling.
Then just reverse it all to put back in.
The oem chome cover has a how to guide included. I can find mine and copy it if you would like to see. Just email and I will get a copy and send back to U. May post here as well if any one else is interested.
Old May 9, 2008 | 07:38 PM
BlackDragon
I made a copy as they were easy at hand.
Hope this helps.
Old May 10, 2008 | 04:02 PM
swordy's Avatar
swordy
Big Kahuna HDF Member
have taken mine off several times most important thing 2 do is wrap an old tshirt or rag round s/arm stop damage,mine dont fit no more as i hav put 07-08 profile tyre on an 06 nt u have 2 grind back top & bottom guards 2 fit
Old May 11, 2008 | 09:32 AM
flyburch's Avatar
flyburch
i put mine on my 03 fatboy wiggling it into place was the only tricky part if i can do it you can i think the instructions posted say for 2007 fatboys so yours and my instructions may be different.. but you can do it
gotmeaharley
Jan 9, 2015 11:10 PM
Sturgis owner
Shovelhead
Jul 24, 2013 12:24 PM
FLTR2008TRIKE
Aug 27, 2012 01:14 PM
Shackleford
Sep 1, 2011 09:36 PM
beerman522
Sep 1, 2007 06:35 PM
