Adjusting Idle on 08 NT
Old May 20, 2008 | 09:18 AM
POKJWS's Avatar
POKJWS
Default Adjusting Idle on 08 NT
Is there a way I can adjust my idle on my 08 NT? Would like to drop it down a few hundred rpm. Currently have PC III installed, but I believe thats a fuel mgt system for mixture ratios? Thanks....
Old May 20, 2008 | 09:38 AM
seaflea's Avatar
seaflea
Default RE: Adjusting Idle on 08 NT
If its EFI the answer is no.
Old May 20, 2008 | 10:15 AM
hoghead58's Avatar
hoghead58
why not seaflea ? i have a injector and i would like to set the idle dowm a little,
Old May 20, 2008 | 10:20 AM
seaflea's Avatar
seaflea
I knew i had read somewhere on here that it wasnt a good idea.
Here is the thread.
https://www.hdforums.com/m_2339263/tm.htm
Old May 20, 2008 | 10:21 AM
seaflea's Avatar
seaflea
had to find the thread to prove to myself That I wasnt making it up! LOL
Old May 20, 2008 | 10:23 AM
jumporjerkoff's Avatar
jumporjerkoff
I had the same problem with the PC111, sometimes it was idling ok, sometimes it would just start idling to fast...one of the tech guys at harley sorted it for me...
Old May 20, 2008 | 11:01 AM
voyager1's Avatar
voyager1
do not reduce idle speed. It has to be where it is for correct oil pressure !!!!!
Old May 20, 2008 | 03:50 PM
jhugs92's Avatar
jhugs92
When using the PCIII, you MUST zero out the throttle setting after installation. If not, it will be at about 7% throttle when bike is at idle. I had to complete the process on my '07. There are instructions on how to do it in this forum, just do a search. The idle should be between 950-1050 RPM's. I would check the RPM's first through the PCIII on a laptop. Hope that helps.
Old May 20, 2008 | 04:08 PM
*NIGHT TRAIN*'s Avatar
*NIGHT TRAIN*
Yeah, this has been around before...lot of people scream bloody murder if anyone talks about going below 1000 rpm...but bottom line is that the service manual recommends 900-1100 rpm on softtails, so a lot of the bikes out there are probably at 900 anyway...my dealer will take it down to 850 if you want...and no, 50 rpm below factory specs isn't going to damage anything...
Old May 21, 2008 | 10:33 AM
voyager1's Avatar
voyager1
I would keep it @ factory specs. I think the people at harley know this better than we do. People want to mess around sometimes, and do not know what they are doing and can cause engine damage. These topics should be posted in the Tech section. IMO.
