replacement bullet rear turn signals only have
Old May 27, 2008 | 08:24 PM
keno's Avatar
keno
Default replacement bullet rear turn signals only have
one wire. My son called and is replacing his rear turns on his 08 Fatboy. Bike has two wires and new turns only have one black wire. Any suggestions for him?
Old May 28, 2008 | 01:32 PM
keno's Avatar
keno
Default RE: replacement bullet rear turn signals only have
Does anyone know how to connect a fatboy blinker that only has one wire coming out of it to the bikes two wires?
Old May 28, 2008 | 01:35 PM
Sublime1's Avatar
Sublime1
It's just a hot, the chassis ground provides the return path.
but, i believe both wires are for brake+turn. IIRC.
You'll just have to break out the multimeter, hit the pedal and see which wire gives you 12v. Then do the same with the TS switch.
Old May 28, 2008 | 01:38 PM
bensonjv's Avatar
bensonjv
Double check part numbers and year/model config. It's not uncommon for you to get the wrong part. Many part numbers are vey close.
Old May 28, 2008 | 04:01 PM
mred1995's Avatar
mred1995
Sublime has it right. The hot wires should be brown and purple coming from thebike(I can't remember which side is which color). Conect the black off the new signal to the brown or purple, and fold the black from the bikeback, I'd cover it with shrink wrap.
hyrax222
EVO
15
Jun 2, 2015 11:54 AM
j88j
Nov 16, 2011 06:28 AM
Kern
May 19, 2009 05:33 PM
brndray
Feb 15, 2008 11:48 PM
tbro90fb
Feb 10, 2007 07:57 PM
