EFI or Carb???
Here's my opinions on the pros and cons of EFI v Carb...
EFI PROS: You can tune it much more accurately, modern system, startups are a breeze, no adjustments necessary for different altitudes, well designed, better gas mileage.
EFI CONS: Dyno tunes are expensive, problems with the computer = a return trip to the dealer (possibly on a flat-bed), personal home tuning is tedious and more expensive (requires SERT and or PCIII with a computer and a little more than basic knowledge - although many tools exist to help you), computer can initiate engine knock (although I understand the SERT can cure this).
CARB PROS: Easy to work on, no computer to fail, overall they're cheaper to redesign or rejet or replace.
CARB CONS: Gotta use choke on startup, known to sputter more, harder to pinpoint tune, primitive (although effective) design.
Not a complete list, just off the top of my head. Any point there could be argued or challenged over and over. I just like the reliability of a carb, even though I admit that EFI is now probably equally reliable. According to my dealer HD won't offer carbs on big twins anymore starting with 2007. I don't mind taking 3 or 4 minutes to warm up my bike. I don't keep the choke on and foul the plugs, either. When I change the pipes, I pull off the air filter and rejet the carb. It requires a little knowledge, but I learned it in auto shop in 10th grade. So, to answer your question.. it's totally up to you. What do you prefer? I'll eventually wind up with an EFI bike. Just not yet. I'm not scared of em, I just still like the simplicity of a carb on a bike. Good luck.
