adjustable push rods?
Old Jul 31, 2008 | 01:07 AM
red deuce's Avatar
red deuce
Default adjustable push rods?
If I go with a Andrews 26g cam and cam gears do I need to install adjustable pushrods? The bike is a 04 fuel injected Deuce with pipes and air cleaner.
Old Jul 31, 2008 | 10:51 AM
grumpy irish again's Avatar
grumpy irish again
Default RE: adjustable push rods?
that is a yes and no unless you want to take the heads off you need adj. pushrods
also different tubes. just cut the old ones in half to get them out .. tubes are to small in dia. for the adj so need new ones that are bigger.
&nbsp\\;
Old Jul 31, 2008 | 06:51 PM
jcboof's Avatar
jcboof
You dont have to take the heads off,&nbsp\\; You only have to take the tank off to get to the rocker boxes.&nbsp\\; I had installed adjustables with bad results, 2 of them broke.&nbsp\\; After all the time i spent trying to get them adjusted correctly,&nbsp\\; I decided to switch back to stock pushrods,&nbsp\\; It only take about an extra 1/2 hour to take the tank off and get to the rocker boxes.&nbsp\\; Save yourself the hassle and just reuse the stock ones.
Old Jul 31, 2008 | 06:53 PM
jcboof's Avatar
jcboof
also,&nbsp\\; you dont have to worry about the adjusters backing off when your on a 500 mile ride somewhere!&nbsp\\; Thats definitely a plus. Adjustables for the most part are OK and completely reliable but I just prefer the stockers.&nbsp\\; Much less to worry about
Flhrhog
Dec 9, 2014 08:15 PM
crazyanimal
May 6, 2013 11:59 AM
rm4040
Feb 19, 2011 03:35 PM
rm4040
Dec 23, 2010 04:34 PM
AK BAGGER
Jul 15, 2010 12:47 AM
