26g cam
Old Aug 2, 2008 | 07:27 PM
red deuce's Avatar
red deuce
Default 26g cam
Is the Andrews 26g cam a good choice for a 04 deuce fi with intake and thunderheader?
Old Aug 2, 2008 | 09:25 PM
cardboard's Avatar
cardboard
Default RE: 26g cam
Talk to a good head man or a builder so you can match yer compression to the cam you choose. The 26 is a good cam for bottom and mid range.
&nbsp\\;
Who's doing the work for you ?
&nbsp\\;
Check out the TW6 Woods cam
or call Bob Woods, he would be able to answer yer question
&nbsp\\;
http://www.woodcarbs.com/
Old Aug 3, 2008 | 11:09 AM
FBTRIKE's Avatar
FBTRIKE
Default RE: 26g cam
If your not doing anything else, its a good cam.....I&nbsp\\;just installed&nbsp\\;andrews TW21 cams on my trike and am very happy with them...lots more low end torque. 26g are supposed to be good on&nbsp\\;a lighter bike, torque curve starts just a little higher than the 21s.&nbsp\\;
Old Aug 3, 2008 | 03:35 PM
jcboof's Avatar
jcboof
Default RE: 26g cam
I had a 26 on my Road king and was VERY dissapointed with it,&nbsp\\; Yes it was installed correctly and my Dyno Tuning was done correctly,&nbsp\\; I now have an S&amp\\;S 510g in my Heritage and it is a exactly what i was looking for.&nbsp\\; If you really want to "FEEL" the cam,&nbsp\\; then the s&amp\\;s is the way to go.&nbsp\\; Otherwise I basically though I wasted my money on the andrews 26.&nbsp\\;&nbsp\\; Now the 37G would be a good choice also!
Old Aug 3, 2008 | 04:45 PM
backcherrydeuce's Avatar
backcherrydeuce
Default RE: 26g cam
Running andrews 37g cams with s&amp\\;s gear drives, big sucker, v&amp\\;h Bss on my 06 injected deuce and all i can say is it pulls HARD!!!!
Old Aug 3, 2008 | 04:59 PM
red deuce's Avatar
red deuce
Default RE: 26g cam
Hey black cherry deuce is your bike stock other then the mods listed?
Old Aug 3, 2008 | 05:06 PM
byersmtrco's Avatar
byersmtrco
Default RE: 26g cam
Curious. Doesn't Andrews (make) S&amp\\;S cams?
backcherrydeuce
Default RE: 26g cam
only mods are pipes, a/c, power commander, and the 37g gear drives. had it dyno tuned before cams and it was 75hp and 74lb. will be going back on for an after cam run real soon.
&nbsp\\;
Old Aug 3, 2008 | 05:08 PM
backcherrydeuce
Default RE: 26g cam
i had heard that andrews makes the gear drives for s&amp\\;s idk about cams.
&nbsp\\;
ORIGINAL: byersmtrco
Curious. Doesn't Andrews (make) S&amp\\;\\\\\\;S cams?
Skip
Exhaust System Topics
Apr 4, 2013 10:31 AM
fidel
Feb 5, 2013 09:09 AM
chunks
Mar 27, 2012 05:05 PM
gpickglwd
Jun 29, 2009 10:05 PM
stinkfist
Jul 6, 2008 08:39 AM
