transmission singing
Old Sep 7, 2008 | 02:21 PM
rickdrwa's Avatar
rickdrwa
1st Gear
Default transmission singing
any have an issue with their transmission sounding like a siren when you start slowing down, its an annoying sound the dealer says it normal sound i dont think so
Old Sep 7, 2008 | 02:37 PM
DECON BLUE's Avatar
DECON BLUE
What year and model?????
Attached Thumbnails transmission singing-100_0585.jpg   transmission singing-100_0586.jpg   transmission singing-100_0577.jpg
Old Sep 7, 2008 | 02:42 PM
Dorkman's Avatar
Dorkman
When you change transmission oil, what's on the magnetic plug? Should just be greyish fine material and tiny shards. Anything more could indicate a problem.
Old Sep 7, 2008 | 02:49 PM
monkyman's Avatar
monkyman
Are you sure it is the transmission? My belt was singing when it got hot because it was to tight. The way I could tell was by pulling the clutch lever in at speed and the pitch never changed. It changed at wheel speed, but not gear changes. It to was only on decel.
Old Sep 7, 2008 | 02:53 PM
shovel52's Avatar
shovel52
My '07 Deuce does this in first gear only. It is not a grinding sound or doesn't sound harmful. It just sounds like straight cut gears. Only does it when decelerating and with the clutch pulled in. It has done since it had .7 miles on it. Ken
Old Sep 7, 2008 | 02:54 PM
rickdrwa's Avatar
rickdrwa
1st Gear
its a 2006 deluxe, and the dealer has changed the trans oil since day one they never said anything and when i pull the clutch in the noise stops
Old Sep 7, 2008 | 03:00 PM
DECON BLUE's Avatar
DECON BLUE
In all gears?, did it just start or has it always done it?
Old Sep 7, 2008 | 03:20 PM
monkyman's Avatar
monkyman
Ok, than that should take the belt out of question. Yeah, if the noise goes away with the clutch in, it sounds like either a transmission noise, or, possibly the primary chain is misadjusted. The noise would change in the primary as the torque is taken off the top of the chain under acceleration and applyed to the adjuster side under decel.
Old Sep 8, 2008 | 07:25 PM
tk353's Avatar
tk353
only in 5th and that was before changeing oil to Bel Ray gearsaver
Old Sep 8, 2008 | 10:09 PM
Alain's Avatar
Alain
I have exactly the same problem with my 08 Rocker c and the dealer mentioned it could be that the belt is on there too tight. The funny thing is that it didn't start making this noise until about 20 miles ago.
At first I thought it was the rear brakes dragging (I actually still think it's the rear brakes dragging). My bike has 947 miles on it and it's going for service tomorrow. I'm going to have them check the bearings, the transmission and the tension on the belt.
Stay tuned
