Passing Lamp Wiring Question
Old Mar 25, 2006 | 06:07 AM
Finalcut's Avatar
Finalcut
Default Passing Lamp Wiring Question
I'm looking at the thread here on HDF https://www.hdforums.com/m_54142/tm.htm
Shows a diagram on how to keep passing lamps on even when brights are on. OK, cool got that...
My question is: If I wanted to bypass the passing lamp on/off switch all together ( if anything just to test to see if the switch is bad )
couldn't I just run the two passing lamp wires together right to the accessory switch wire that connects to ACCY:15A ???
I don't need an on/off switch. I'd just assume pull it out of the mix.
mikebaby
Aug 21, 2012 08:31 AM
Armstronges
Jul 1, 2012 05:20 PM
relli
Jun 18, 2007 01:28 PM
ndotken
Dec 29, 2006 08:19 PM
rbcss
Dec 15, 2005 09:00 PM
