Braided cables / brake lines
Old Mar 27, 2006 | 03:40 AM
DanDeuce's Avatar
DanDeuce
Default Braided cables / brake lines
Just finished putting braided brake lines , front and rear , clutch and throttle cables on my Deuce . Looks a lot better now for under $300 , got my parts at 20% off from Chicago HD . Not a tough job although it took a while because of having to remove gas tank , loosen exhaust , etc. plus the front brake gave me fits trying to bleed it . Total time , about 6 hrs , taking my time . Anyone have any idea of what the stealer woulg charge for that work ? Know I saved a bundle !
To those who have trouble bleeding their front brake I stumbled on the cure , at least for me . They manual say to squeeze the handle a few times to release air trapped in the master cylinder (M/C) , well theres lots of air in there , a whole lines worth ! The M/C will not force anything out with any air in the M/C . Tap the brake lever vertically with your fingers . It may take 10 minutes or so but eventually all bubbles will work there way up and out and you will finally feel some resistance and then you can bleed the brakes as any other . Not sure why the rear bleed so easily and the front did not , I suspect it is because the front line is vericle for most part as compared to the rear which is horizontal .
Dan
Old Mar 27, 2006 | 10:38 AM
vulhalla's Avatar
vulhalla
Default RE: Braided cables / brake lines
I just had Braided put on mine, I think they are an excellent choice
Old Mar 27, 2006 | 11:05 AM
TxMoores's Avatar
TxMoores
Dan,
Another, perhaps quicker, trick is to use a clean oil squirt can and a piece of tubing and fill the system from the bottom up. An ol fart showed me this trick years ago on an ironhead and it works sweeeeet!!
Old Mar 27, 2006 | 09:22 PM
BlueDeuce's Avatar
BlueDeuce
ORIGINAL: TxMoores
Dan,
Thats how I done mine. Couldn't get her to pump up any other way.
Old Mar 28, 2006 | 11:10 AM
fatheadonsoftail's Avatar
fatheadonsoftail
Thanks for the Info. My SS Cables and Brake Line are arriving via UPS Today and I can finally put the bike back together.
Weather here is supposed to be in the 60's by Friday so I need to get this done asap!!
WOOOHOOO
jlilnc14
May 20, 2012 02:05 PM
srm148
Feb 2, 2010 10:58 AM
devils haircut
May 18, 2008 08:40 PM
Gnight
Apr 3, 2008 02:38 PM
SubZer0
Apr 14, 2006 01:02 AM
