2004 softail with dual disc front. Any thoughts?
Old Dec 6, 2008 | 06:48 PM
michael95688's Avatar
michael95688
Default 2004 softail with dual disc front. Any thoughts?
I'd like to do a dual disc set up on my 2004 Deuce and aside from the obvious need for slider and caliper, caliper bracket and brake line I see the master cylinders are different too. I'd like to do as much of the conversion as I can gradually. I'm wondering if the larger dual disc 2006 Dyna / Softail master cylinder is compatible with the 2004. It's bigger and too much master for the 2004 but will it fit? If not which should I use? I want the full benefit of the bigger master if possible.
I'm looking at using the chrome clutch bracket and master cylinder kit HD#46418-05A to get the project started. Anybody done this? Any thoughts?
Old Dec 7, 2008 | 12:59 AM
5speedblu's Avatar
5speedblu
why ?
a single 4 piston or 6 piston will stop & look better. not to mention the new lower leg you need.
Old Dec 7, 2008 | 10:03 AM
tmitchellof PG's Avatar
tmitchellof PG
Originally Posted by 5speedblu
why ?
Exactly.
Tom
Old Dec 7, 2008 | 10:10 AM
anubisss's Avatar
anubisss
Get yourself a 6 piston PM. They aren't cheap, but well worth the dough.
Old Dec 7, 2008 | 01:04 PM
CANTDR55's Avatar
CANTDR55
Default duel disk
I researched this back about a year ago. I'm doing the PM caliper instead but the Screamin eagle Deuce had a duel disk set up. You can use that set up and bolt it all on to your bike. You'll need to change out the master cylinder.
rob
2005 nightrain
Carbed.
Stage I
Roland Sands Design VENTURI AIR CLEANER
Arlen Ness forward control extension kit.
V&H Straight shots
Radiant Side mount license plate light with LED cats-eye (discontinued)
Kuryakyn LED side rear marker/ turn lights
HD Diamond Back solo seat
Old Dec 7, 2008 | 06:00 PM
michael95688
Interesting. I hadn't considered the 6 piston option. Anyone got a photo or a part number? Do you use the 11/16" (Harley #46418-05A) Master listed above or??
Michael
Old Dec 7, 2008 | 07:03 PM
agapsdiver's Avatar
agapsdiver
What CANTDR55 said.. the 2004 SE Duece had a dual disc forks/setup...just buy it.
Old Dec 8, 2008 | 01:25 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
rob
Didn't it also come with a larger (wider/fatter) front tire?
I'm a bit leary of putting too much brake on the front of any bike. Putting a set of dual calipers and rotors on to a stock skinny 21" tire would make me a bit nervious.
A lot of people think there is no such thing as too much brake, but any wheel/tire/brake combination that lets you easily lock up the front is too much.
I dropped a bike by locking up the front tire once and don't want to try that trick again. It hurts a lot and doesn't do the bike much good either.
Besides one of the better 6 piston progressive calipers with braided lines, decent pads, and a good two piece rotor is going to be at least as good and have a better 'feel' than a set of stock solid disks and calipers.
It will also be cheaper and a hell of a lot easier to put on.
Anyone who's done it can tell you that if the new dual caliper setup doesn't want to play nice, it can be a real pain in the azz to get working properly.
Old Dec 8, 2008 | 01:46 PM
mopardave's Avatar
mopardave
I would buy the floating rotors from HD at $120 each and the LRB Z+ pads at about $40 a set. The stopping power is great...no dust....they last a long time!!!
Old Jan 28, 2009 | 04:52 PM
michael95688
I've made a decision. I'm doing a 6 piston on my Deuce. I'm using a late model (2005 and up) touring bike master cylinder (it also fits 2004 and up Dyna). The mc fits no problem but the banjo fitting is smaller so you'll need a 10mm unit instead of the 12mm line you have now. In my case it was pretty painless because the original owner of this bike installed a goodridge brake line that allows you to mix and match. All I needed to do was replace the banjo, the bolt and the washers.
Roadkill73
Jan 19, 2014 10:45 PM
phidoux
Jan 25, 2012 11:29 AM
Chopperguy99
Wheels/Tires
Aug 19, 2011 11:58 AM
Figstr
Nov 8, 2009 08:48 AM
vtarandy
Sep 4, 2008 05:50 PM
