Braided cables question
Old Dec 17, 2008 | 06:53 AM
Twan's Avatar
Twan
Cool Braided cables question
I am looking to change my cables over to braided,but having a hard time finding the front brake line for 08 Fatboy.I want it to match,as in the same manufacter.Drag speciatlies only has the front brake line listed up to 07 for the FLSTF.Will this fit the 08?
Any help would be appreciated with which cable/lines that would work the best.
Old Dec 17, 2008 | 07:48 AM
5speedblu's Avatar
5speedblu
did you check with Barnett?
Old Dec 17, 2008 | 08:54 AM
ronyd's Avatar
ronyd
checkout http://www.magnumshielding.com. I used the for control cables and brake lines...
Old Dec 17, 2008 | 09:09 AM
P'colaHarley-17RGS's Avatar
P'colaHarley-17RGS
if it fits an 07 it should also fit an 08 or 09 right?
Old Dec 17, 2008 | 09:54 AM
ngoti8tor's Avatar
ngoti8tor
Someone said in an earlier post that they couldn't tell the difference between the Drag Specialties cables and the HD Diamondback cables.
I just ordered all my Diamondback cables for my 08 Fatboy yesterday from HD. The part number for the upper brake line is 44964-07 and lower brake line is 42371-07.
Old Dec 17, 2008 | 01:27 PM
mimo's Avatar
mimo
+1 Check out the Chromite II series. I have the entire setup from them, pretty nice stuff.
Mimo.
Old Dec 17, 2008 | 02:25 PM
Twan's Avatar
Twan
Smile single ,upper or what
Memo,
Should I go for the single cable or the upper and lower assembleis or the single with the swivel ends?\
These are from Magnum,
and thanks for the info,
Old Dec 17, 2008 | 05:14 PM
mimo's Avatar
mimo
Originally Posted by Twan
Memo,
If it is brake line you're talking about, I went with single piece and 90 degree on both elbows.
Mimo.
Old Dec 18, 2008 | 06:42 AM
Twan's Avatar
Twan
Smile
Thanks Mimo, for the info
Old Dec 18, 2008 | 07:38 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
If you get the Magium Chromite II's, your actually getting the HD Diamondbacks under their name.
When I visited them to get mine (they are in town here) I found out that they are the people who make the Diamondbacks for Harley. They just don't put the black covering over the lower half of the clutch cable the way they do for Harley.
Stick with what Mimo said, a one piece brake line means there are that many fewer places for leaks to show up later.
Chromite II and Diamondback clutch cable, can you tell which is which? I can't and I took the pic.
barrkeys
Mar 15, 2011 08:48 PM
brettnbama
Jul 20, 2010 04:18 PM
Frog74
Mar 26, 2008 03:16 PM
Gunshow
Jan 15, 2008 10:43 AM
Rev00
Jan 9, 2008 06:22 AM
