running/brakelight kit for softails
Old Dec 23, 2008 | 03:31 PM
schumacher's Avatar
schumacher
so that's what might screw up.......
thanks for the info. I do a lot of long runs on hot summer days. Maybe I shouldn't do the mod then.
Old Dec 23, 2008 | 03:47 PM
BlockHead96's Avatar
BlockHead96
Just try it, but be aware of it when or if it happens. When it happens, the first thing that comes to mind is, WTF just happened????? You don't think of what you did to the bike may have caused the result. You automatically think something is wrong and don't know what it is or it's cause. You end up chasing, testing, replacing other stuff in hopes it fixes it or goes away. The dealers have no clue or care, they are there to separate you from as much of your money as they can.
Old Dec 23, 2008 | 03:57 PM
Mordrapheus's Avatar
Mordrapheus
I did the mod on my 09 heritage, easy as 123 to do. so far no probs with it, though I did see the mention on the paperwork that came with the mod...aslo not had tomany sommer rides yet so not sure yet.
Keeping my fingers crossed
Old Dec 23, 2008 | 04:14 PM
Bluzmn59's Avatar
Bluzmn59
I have now had the kit on five bikes, all with factory security systems and not one problem.
Old Dec 23, 2008 | 10:46 PM
BTL's Avatar
BTL
Just did this mod a couple of days ago, its plug and play, but since its winter time wont know if it has the problem of shutting down but it will be the first thing i check this year if ai have any problems.
Old Dec 24, 2008 | 09:18 PM
BlockHead96
For whatever unknown reason, some bikes are effected and some are not. I'm not done testing mine as the bad weather is here. When I removed mine, I took it on a 114 mile run, it did not shut down. When the mod was in place, it would always shut down within 75 miles of a continuous run. Does this mean it is in fact that module?? I hope so, but maybe one run isn't enough. The problem sue is pointing in that direction right now!
Old Jun 2, 2009 | 06:55 PM
BlockHead96
The turn signal kit is a problem!!! It IS the culprit!!
Old Jun 2, 2009 | 08:43 PM
schumacher's Avatar
schumacher
Least you found it. I've had no problems so far with the Kury kit.
BlackBetty
Jan 11, 2014 11:33 AM
Mill908
Nov 30, 2012 11:25 PM
Bluerose
Sep 15, 2009 04:18 PM
ndnhog
Feb 9, 2008 09:47 PM
FLEKIS
Aug 2, 2007 12:17 PM
