Fender Extension Install (with pics)
Here goes:
Here is the before pic:
First, put the bike on the lift, and disconnect the battery cables per instructions.
Then, pull the old mudguard, only two bolts. This exposes all the electronics protected by the mudguard:
Then take the two nylon nuts and screw them on to the two terminals in the picture:
Next, take the two clamps from the kit and hook them around the top of the swingarm as shown:
Then slide the fender extension between the rear wheel and the swingarm. Attach the extension to the clamps at the top with the supplied cap head screws:
You then, do the same with the two bottom screws using the same speednuts used for the mudguard:
Lastly, make sure you have proper clearance for the belt and brake line:
I preshaped the fender extension on my leg to match the curve of the swingarm before inserting it.
Here is a view of the right side:
Here is a view of the left side:
Like I said, this is not a major mod or anything, but definately gives it a different look and gets rid of the cheap looking plastic. Plus, I always wanted to see one before buying it, but I took one for the team so you can benefit from my experience.
Saint, Dr. Greenthumb has one on his bike and he powdercoated it black. Just an idea.
