widest tire on 06 deluxe
Old Jan 22, 2009 | 08:13 PM
deluxeglide's Avatar
deluxeglide
1st Gear
Default widest tire on 06 deluxe
Does anyone know what is the widest tire that will fit an 06 Softail Deluxe without making any major mods??? I believe stock is a 130 and it looks like I have plenty of clearance with the fender, pulley, and belt guard. I have contacted a couple dealers and they all tell me something different. They all tell me something different as to how wide my tire is (MU85B16 77H ) I've been told it's a 140 and 150 but if im measuring correctly it's a 130.
Old Jan 22, 2009 | 09:26 PM
WARG's Avatar
WARG
If the tire on the rear of the 06 Deluxe is the same as my 06 Fatboy (I think it is), then it's a 150. I'm not sure about tire size, but I was told my a guy at www.bikersimage.com that I could replace my 3.5" rear wheel with a 4.25" width wheel. So that would mean using a wider tire right?
Old Jan 22, 2009 | 10:39 PM
WarriorHD's Avatar
WarriorHD
This size (MU85B16 77H ) translates to about a 150. Not sure of the widest you can put in there on the stock wheel, but curious to find out.
Old Jan 23, 2009 | 07:33 AM
tk353's Avatar
tk353
i can email you a Metzler chart if you pm me with your email address.
140/90 MU85/MU90 5.50 to 6.00
Old Jan 23, 2009 | 08:00 AM
tmitchellof PG's Avatar
tmitchellof PG
From what I have read, 160 is about as wide as you can go, without doing modifications on my 2005 Fat Boy.
Tom
Old Jan 23, 2009 | 12:35 PM
P'colaHarley-17RGS's Avatar
P'colaHarley-17RGS
think it's the same as the 06 Fatboy and I've been told that it's 150 and that I could go
to 180 without changing the swingarm, spacers etc...
Old Jan 23, 2009 | 04:34 PM
tmitchellof PG
Without even considering belt clearance, my 150 tire rides pretty close to the fender, on the left side. I would think a 180 would be a very tight fit.
Tom
Old Jan 23, 2009 | 05:49 PM
edeluxe07's Avatar
edeluxe07
I have a 150 Metzler on my '07 deluxe.....should be the same for an '06 as I don't think they changed the deluxes'
Old Jan 23, 2009 | 07:15 PM
deluxeglide
1st Gear
I looked up the specs on a Fatboy and in 2006 the tire is a 150/80-b16 which is not the same as a Deluxe. I saw an 08 Deluxe at the dealer today and there is definetly more clearance all around on my bike. I have about 3/4" clearance per side on the fender, and also about 3/4" with the lower belt guard. The swing arm, pulley, and brake are no where near the tire. I am ready for a new tire that is why I want to go wider but have no intention of changing the rim. I think even if my tire is a 130 that I have the room for a 160, but don't know if it will fit on the stock rim...
Old Jan 23, 2009 | 09:07 PM
stratplexi's Avatar
stratplexi
I believe the stock tire is a 140 for the Deluxe and the Heritage and Fatty for those years are a 150. The reason is that Dunlop does not make a WWW in a 150. I believe Metzler or Avon, can't remember which, makes a WWW in 150. The bike will take a 160 but I don't know of a WWW in that size.
