softail standard tail light options
Old Jan 25, 2009 | 04:04 PM
schumacher's Avatar
schumacher
Default softail standard tail light options
Been thinking of maybe switching out my tail light when I put the Haulen *** plate bracket on mine.
Seems most of the lights fit 99 and back, and 06 and up.
Anyone know of any for 2000-05?
Old Jan 25, 2009 | 04:30 PM
dennyo's Avatar
dennyo
This is the One I'm Usin ,,
But U have to Rewire it it's fur 99 and earlier
Old Jan 25, 2009 | 06:26 PM
schumacher's Avatar
schumacher
yeh, I've seen that one. Was it hard to re-wire?
Old Jan 26, 2009 | 10:36 AM
dennyo's Avatar
dennyo
I Used the Trial & Error system.....
I think there Was 3 wires coming out of the Light
and 5 Wires goin in....
Hooked-um up and checked to see if everthing worked
If Not Hooked-um up another way.....
Some one may make-um for Later Models now did mine 6 years ago.... hope that helps...
Old Jan 26, 2009 | 12:31 PM
beaureed445's Avatar
beaureed445
I'm using the Kurayken Pancea tail light, with built in signals...I like it. Had the same one on my '03 Sporty.
Old Jan 26, 2009 | 02:46 PM
imboden's Avatar
imboden
I put the side mount plate on mine and kept the original brake light. used my dremel tool and cut out the plastic mount under the brake light.
Old Jan 26, 2009 | 03:25 PM
schumacher's Avatar
schumacher
My scoot has a Kury Panacea light in it now, but I was hoping to find one that filled the fender like those new tri bar HD ones.
My current:
Old Jan 26, 2009 | 03:46 PM
beaureed445
My current:
If you're running the pancea tail light, why do you still have turn signals? Doesn't it have the integrated signals, or did someone not hook it up right? That way, you could get those unsightly signals off the rear end, and clean up the look.
Old Jan 26, 2009 | 03:52 PM
schumacher's Avatar
schumacher
It wasn't wired up that way, I guess. I don't mind having signals though.
Old Jan 26, 2009 | 06:23 PM
Buddha4's Avatar
Buddha4
I have a Heavycycle LED light w/turn signals They take a while to get but they; are hand built with lifetime Warranty. The Heavy cycle are MUCH brighter than the Kuryakyn
