trouble changing down gears
Old Mar 1, 2009 | 02:19 AM
hddee's Avatar
hddee
Default trouble changing down gears
my 2007 fxst has trouble changing down gears sometimes.you sometimes have to shift down twice to get it to change down a gear.i take my hand of the clucth and foot of the gear lever and go to change down and the gear lever goes all the way down as if you have dropped it down a gear and you dont feel it change when you push the lever down but when you let the clutch out it is still in the same gear so when you change it again it will then drop into gear .it is not everytime but it does happen a fair bit
Old Mar 1, 2009 | 10:43 AM
TexFordD's Avatar
TexFordD
How cold was it? How long into the ride ? and what oil are you using in the tranny?
Old Mar 2, 2009 | 12:43 AM
hddee's Avatar
hddee
summer in oz at the moment and about 2 hours into the ride and not sure on oil as i have just bought the bike
Old Mar 2, 2009 | 06:57 AM
tk353's Avatar
tk353
change the trans oil to bel ray and primary to motor factory and the issue will be gone
Old Mar 2, 2009 | 08:29 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
You might try to pull off the pedal to clean and re-grease the pivot point as well as the linkage rod ends.
The stock linkage rod has ends on it that are easily gummed up with crap. Good excuse to replace the rod with one that has hyme joints on the ends.
The shift pedals pivot point is notorious for getting gummed up and causing problems. Its not sealed in any way so pulling it off and cleaning it up with new grease can make a big difference in how things work and feel.
Changing the tranny oil for a better grade of synthetic is not a bad idea, but the odds are that your problem has more to do with your ability to easily move the shift lever then the trannys ability to do so.
As a last resort you might try adjusting the linkage to move the shifter peg up a little. That should make it easier for you to push the peg harder, farther.
BigRagu
Aug 21, 2017 07:24 AM
Carmell RKC
EVO
Oct 4, 2016 10:54 AM
racer11
Feb 19, 2016 11:13 PM
shovelryder
Shovelhead
Sep 1, 2012 01:39 PM
Slakass
Nov 29, 2005 11:45 AM
