Is the Deuce swingarm the same as other soft tails? I see on ebay, there are several that say they fit all 00-06 soft tails however, HD has different part numbers for each.
'00-'05 the Deuce swingarm was the same part # as the rest of the Softails. I would think the '06s would have to be different because of the "ATV" rear tires on the new Softails...
You are right! I read your post and thought you were wrong one the older softails but i was wrong ,should of checked.
All swingarms are the same except the newer 06 fat tires.
