Fender Bolt Question
Old Apr 3, 2009 | 02:34 PM
Trout Bum's Avatar
Trout Bum
Correct---The plate spans two bolts you'll be fine
Old Apr 3, 2009 | 02:53 PM
hellfish's Avatar
hellfish
Hey thanks a bunch to all you guys!
*ROCK ON!* \m/ \m/
Old Apr 3, 2009 | 05:06 PM
JR Ryder's Avatar
JR Ryder
Yep the plate is supported by two bolts, AS WELL, it has little insert extensions that protrude though the holes in the fender to keep a very small gap between the strut and the fender, (possibly to protect the paint??). You probably could not remove that plate if you wanted to if you only removed one bolt. I think I have pics. I'll go see, and if I do, I'll throw them in my photobucket and post here in about ten minutes..... JR
EDIT: okay, I found some pics. Look at the one photo where you can see the can of S100. Right above the white rag, you will see the 2 plates that we have mentioned on here. See the nipples sticking up? Those are what I'm talking about.... JR
Old Apr 3, 2009 | 07:06 PM
anubisss's Avatar
anubisss
My 2002 has the bolts held on by nuts behind the fender, but it looks like the bolts thread through the plates on your model. If you take one off at a time I think the plate should stay where it is.
Old Apr 3, 2009 | 10:59 PM
JR Ryder's Avatar
JR Ryder
Yes, the plates are threaded..... no nuts (on a Fatty anyways)
Old Apr 4, 2009 | 06:49 AM
Blk and Chrome's Avatar
Blk and Chrome
All the new bikes have the plates in the fender, the older ones used bolts, a PIA, sure makes it easier now for us and the MoCo
Old Apr 4, 2009 | 07:05 AM
IronAss's Avatar
IronAss
Just put a rear crash bar on my Springer Classic and had to remove that same bolt to do it. Go ahead and remove it. When you put it back in you might have to reach up inside the fender and hold the bracket in against the fender to get the bolt started as the bracket will push in some (but won't come out). The bolt isn't very long so depending on what you are attaching to it you may need to go to the hardware store and get a longer bolt.
SOA
May 3, 2018 04:18 PM
NoRegerts
May 25, 2013 10:32 PM
DirtyThirty
Mar 20, 2011 09:49 PM
mballinger
EVO
Feb 6, 2011 11:51 AM
