Rocker mod ?'s
Old May 3, 2009 | 09:16 PM
Mopardik's Avatar
Mopardik
Default Rocker mod ?'s
I'm looking to lower my Rocker a little, and maybe install a tank lift. Any suggestions on which kits to use, and where to get it? Will I need a shorter kickstand? Also, what is the website address for Heartland? Thanks.
Old May 3, 2009 | 09:36 PM
57RebelRocker's Avatar
57RebelRocker
here are some hope they help...I haven't had to get a shorter stand and mine was lowered 2"...on the lowering site it's the third selection over from the right
http://www.progressivesuspension.com...ies/index.html
http://chopperstyle.net/shopping/ind...70d6008c298683
http://www.heartlandbiker.com/
Old May 3, 2009 | 10:17 PM
Mopardik's Avatar
Mopardik
Thanks Reb. I did a search and found a couple of your posts on it (guess I should have done that first, huh?). I think I may go with that one. How's the ride? Did you replace the bumpstop?
Old May 3, 2009 | 10:38 PM
Windeed's Avatar
Windeed
I used the softail lowering bolts from Arlan Ness on my bike last year. Ride was very stiff. This year I have used Progressive 422 shocks and changed the bump stop. Was able to keep the bike lowered, still have a decent ride, but there may be issues with the rear fender kissing the trick seat now since there is more travel in the swing arm. Time will tell as I ride this summer. It may be another week or more before I have final pics to post, I am waiting for a new front fender.
Old May 3, 2009 | 10:47 PM
Mopardik's Avatar
Mopardik
So which bumpstop do I order at the dealership?
Old May 4, 2009 | 12:07 AM
Joe What's Avatar
Joe What
if u have a grinder and drill with bit u can build your own tank lift.. 1" width by 1/8 " thick flat steel from home depot, stainless steel or chrome bolts from ace hardware and fuel line from auto zone and you have a kit for under 15.00 dollars.. hours worth of work and you should a self made mod.. good luck with your mods...
Old May 4, 2009 | 11:58 AM
Mopardik's Avatar
Mopardik
Thanks, Joe. I was looking at some and there didn't seem to be that much to them, easy fab job. I'm on it! And Reb, I ordered the Progressive lower kit. Will I need to press out the shock bushings with it, like it says? Also, is the ride harsh, and what bumpstop do I order? Thanks again for all the help, guys!
Old May 4, 2009 | 12:10 PM
57RebelRocker
my bumpstop came with the heartland kit...and yes you will have to use a press to change out the studs
Old May 4, 2009 | 12:19 PM
Mopardik's Avatar
Mopardik
Well, crap, I didn't get it from Heartland. Anyone else know what stop to use, is it the standard Softail one? Or will Heartland sell just the stop?
Old May 4, 2009 | 01:31 PM
jasonhua's Avatar
jasonhua
If you just lower it around an inch or so, you don't need to change the bump stop. At least I didn't have to. For 1 inch lower, the ride a little stiffer but not that bad, looks alot better though.
