Tach bracket
Old May 4, 2009 | 12:14 PM
Mopardik's Avatar
Mopardik
Default Tach bracket
Well, I did a search and it appears I'm not alone in needing a tach bracket that will bolt onto the bar clamps for my Rocker. So it looks like the fab route for me, unless anyone else can chime in with a solution. If not, anyone interested in me making one for their scoot as well?
Old May 5, 2009 | 11:37 AM
tk353's Avatar
tk353
Separate purchase of application-specific Mounting Brackets and Gauge Housing is required.
harley part
Old May 5, 2009 | 12:48 PM
bensonjv's Avatar
bensonjv
I share your pain. I had the same problem with my Springer. Lots of options for standard spread risers and bars. Springers are spread wider and obviously the Rocker's setup a unique as well.
Unless HD or some other aftermarket company decides to make one for the OEM Rocker bar/riser configuration, you may be out of luck for a bolt-on solution.
So you can...
1. Fab your own
2. Swap your OEM rocker bars and risers for standard risers and bars. Then options for a riser mount bracket are available.
3. Install an integrated tach/speedo in the dash.
4. Install a tach mounted in a different location. Some offer setups to mount on the fork tubes, off the side of a rocker box, and maybe some other areas.
Good luck. Post pics of whatever you end up with. Rocker folks will be interested as will the rest of us.
Old May 5, 2009 | 09:55 PM
tnharley7's Avatar
tnharley7
I also share your pain. I have a mini 2" HD Tach that I have been trying to mount to my XBones but without any luck yet. Keep us posted on what you come up with.
Old May 5, 2009 | 10:47 PM
Mopardik's Avatar
Mopardik
Will do, guys. I have a template made up, and I know a guy through my work that can waterjet it for me fairly cheap. I'm thinking of using stainless, that way I can polish it and have chrome finish without the added expense and trouble of chroming it. Just curious, but what is the bolt spread across on your Springer frontends?
RockerRat
Oct 24, 2010 08:49 PM
sanlyn
May 8, 2010 12:34 AM
hell hound
Jan 9, 2010 11:21 PM
240rear
Oct 26, 2009 12:49 PM
cactus789
Oct 24, 2009 12:52 PM
