Question
Old May 8, 2009 | 10:14 PM
harley1969's Avatar
harley1969
Default Question
Hey guys im replacing the stock master cylinder cover with the chrome cover. Just the cover keep in mind. Question is will i need to bleed the brakes if im just replacing the master cylinder cover? I tried taking the stock cover off today and it started leaking a little, so i tightened it back up till i get the facts on what to do.
Old May 8, 2009 | 10:20 PM
keno's Avatar
keno
Shouldn't have to bleed them if you are only replacing the cap/cover.
Old May 8, 2009 | 10:23 PM
LH's Avatar
LH
Arrow
No, you don't have to bleed the brakes ...Make sure the master cylinder is level when you take the top off, else you'll have leakage.
Other Sheep's Avatar
Other Sheep
Remove two screws. Lift off cover. Place new cover on resevoir. Install two screws. Clean fluid off bike. Might want to cover any parts that may get fluid dripped on while you're doing this delicate mechanical operation.
Old May 8, 2009 | 10:35 PM
57RebelRocker's Avatar
57RebelRocker
no need
Old May 8, 2009 | 11:23 PM
oct1949's Avatar
oct1949
+1 on getting any fluid on part or paint, U won't like the results...
Old May 9, 2009 | 08:03 AM
tk353's Avatar
tk353
yep cover the bike with shower curtain $2. you will be glad you did. if it had been a while then while your there flush the fluid. it is about the same amount of work and will save you from doing it later. dont over fill.
mang0
Jul 25, 2012 09:24 PM
studiopeg
Dec 22, 2011 11:59 AM
speedwaysteve
Jul 17, 2010 03:17 PM
Drifting Texas
Mar 1, 2008 05:54 PM
Drifting Texas
Feb 29, 2008 09:08 PM
