leaky master cylinder cover
Old Jul 16, 2010 | 08:42 PM
speedwaysteve's Avatar
speedwaysteve
Default leaky master cylinder cover
on my 2010 s/g with abs i notice a lil brake fluid around the cover ive taken the cover off cleaned it and put it back on making sure it was tight,still geting a lil leak.any one eles have this prob
Old Jul 16, 2010 | 08:45 PM
dawg's Avatar
dawg
Common problem. My 08 leaked and bubbled the paint on the cover, replaced cover and gasket under warranty, leaked again so I finally gave up and got a chrome master cylinder cover.
Old Jul 16, 2010 | 09:27 PM
speedwaysteve
thanks guess the chrome one is a better seal
Old Jul 16, 2010 | 09:31 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Problem on my '08 (and several other 08s) but my '09 hasn't done it.
Old Jul 16, 2010 | 09:35 PM
Craig4711a's Avatar
Craig4711a
check the torque on the screws..... it's like 6 in/lbs... which is like nothing. In the "fix my hog" chapter on brakes... they say if you over-tighten the screws on the caps, they'll leak. Just sayin........
Old Jul 16, 2010 | 09:38 PM
RK14SGS's Avatar
RK14SGS
+1 on this... had a gift card for $30 and the difference was $40, so out of pocket for me was $10... Thank you warranty... 09 Road King Classic here...
Old Jul 16, 2010 | 10:11 PM
speedwaysteve
ok ill check the torque i might be making it to tight causing the gasket to squeeze out .. thanks
Old Jul 16, 2010 | 10:13 PM
PWFD's Avatar
PWFD
Yup, this seems to be an issue for a lot of folks. I had two 08's both did it. My 09 Ultra does not have any issue as of yet. One would think this wouldn't be a common problem but it sure seems to be...
Old Jul 16, 2010 | 10:17 PM
speedwaysteve
ive had a few softails and buells never had a prob. with this..wasnt sure if it had something to do with abs.thinkin more brake pressure but seems to common for some .. kind suxs
Old Jul 16, 2010 | 10:48 PM
iclick's Avatar
iclick
They supposedly redesigned the internal rubber baffling and/or the cover around mid-'08. I knew about the problem with '07 and '08 models and kept an eye on it. When it started oozing two years ago and I had them replace the cover assembly in warranty before it did any damage to the MC housing itself. No more problem after that, so I assume the redesign of the baffle was successful.
