To Much Oil or What?
Old May 21, 2009 | 05:50 PM
karbar99's Avatar
karbar99
Cool To Much Oil or What?
Why is it that when I change oil in either one of our Softail Deluxes (an 05 & 06) that after putting in what the book calls for (3.5 qts) that it's always over full and I end up draining back out nearly over 1/2 qt.
Yes, I'm checking it warm and on the jiffy stand, not on the level.
Anyone else have the same problem?
Barry
Old May 21, 2009 | 05:53 PM
hspring03's Avatar
hspring03
my 03 never takes more than 3 qts.....
I've heard that from many people
Next time, check the dipstick before putting in that 1/2 quart
Old May 21, 2009 | 07:35 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
It is because when you drain the oil there is still some that stays in the engine due to it's design. If you look at the service manual it says 3.5 quarts for a totally dry bike. Fill up 2.5 and run the engine a bit to let it circulate. Check and fill as necessary.
Old May 21, 2009 | 07:40 PM
TexFordD's Avatar
TexFordD
at normal temp let bike idle for 1 minute shut off without 'burping' it and then check
Old May 21, 2009 | 07:44 PM
BoomerBob's Avatar
BoomerBob
There's a new one on me. What do you mean by "burping" it?
My Softy takes 3 qts even. My touring bike take 4 qts even.
Old May 21, 2009 | 07:53 PM
TexFordD's Avatar
TexFordD
right 'dar in the manual
page 1-12 2008 manual ride to normal operating temp let idle 1-2minutes on stand shut of and check level.
Burping is that burp you give and cut off to clear the cylinder
Old May 21, 2009 | 08:06 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Clear the cylinder? Of what? Sounds like junk science...
Old May 21, 2009 | 08:25 PM
rbabos's Avatar
rbabos
What HarleyGoodies said. Simple as that.
Ron
Old May 21, 2009 | 08:43 PM
DaddyKnuck's Avatar
DaddyKnuck
never heard it called a "burb" before. Seems like a good way to scrub oil off the cylinder walls insuring a nice metal to metal contact the next time you start up.
ElectraJim
Oct 2, 2021 12:27 PM
SoftailSlim_Rider
May 16, 2018 12:29 PM
pomeara
Milwaukee Eight (M8)
15
Jun 8, 2017 10:23 AM
guido700
Mar 16, 2017 09:46 AM
beary
Jul 24, 2009 08:47 AM
