rocker comfy
Old Jun 7, 2009 | 01:53 PM
cccsclark's Avatar
cccsclark
Default rocker comfy
is there a way to be comfortable on a rocker my lower back kills me i have a danny gray seat any suggestions
Old Jun 7, 2009 | 01:57 PM
Xuallus's Avatar
Xuallus
apes
Old Jun 7, 2009 | 03:01 PM
Alain's Avatar
Alain
yeah, the only thing i would say is apes !!
Old Jun 7, 2009 | 03:22 PM
cccsclark's Avatar
cccsclark
aapes will cure the lower back problem really seems like arms would go num
Old Jun 7, 2009 | 03:41 PM
Xuallus's Avatar
Xuallus
no problem here... If you keep them close to shoulder height you should be ok.
Old Jun 7, 2009 | 04:27 PM
bikermike2's Avatar
bikermike2
ya put your original seat back on & flip the back set up. put in bar & now you have a backrest.
Old Jun 7, 2009 | 08:11 PM
m i k e's Avatar
m i k e
apes ok yeah apes are comfy
maybe some gel thats the route i wanna take
Old Jun 7, 2009 | 10:10 PM
rubiconMike's Avatar
rubiconMike
I used to feel it quite a bit in my lower back until I put on my mini apps (monkeys) and my springer seat. Since I did that I haven't had any lower back problems.
Old Jun 8, 2009 | 05:32 AM
Rocker_Dan's Avatar
Rocker_Dan
gel helps a lot....rub some on before and straight after a ride...
Old Jun 8, 2009 | 08:41 AM
Rocker_C's Avatar
Rocker_C
If you don't want apes or the expense of changing over to them try this it worked for me and it’s free. Loosen the 4 handle bar clamp bolts a little so the bars turn but won’t flop freely. Each side will turn independently. Sit on the bike and turn the handlebars so they are closer to you making sure they are even. Tighten the 4 bolts and turn the controls around to where you like them. I was able to bring the bars back about 2 inches so I'm not reaching out as far and had less back strain.
