wires thru bars
Old Jun 15, 2009 | 08:38 AM
2001 Softail Deuce's Avatar
2001 Softail Deuce
I did it for the first time a few weeks ago. Trile and error, lots of error but I took string and sucked it through with the shop vac. I used the lite string to pull a bigger wire through then used that bigger wire to pull the bikes wires through. I tried the nut trick put didn't work very well, the vac worked great EVERYTIME I had to retry. I used Pam spray on the wires. But be careful with how much you spray. We had Pam everywhere and had to mop the garage floor to stand up. Fingers got too slick to hang onto the wires, electric tape, or anything. On one side I had to seperate the wires in equal amounts and pull both set through seperately.
Old Jun 15, 2009 | 08:41 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
I tied long strings to the end of the bars and sucked the string through the bars with a vacuum cleaner. the nut on the end of the strings sounds like a good method too. Any way you toss, it is a PITA. A lot of people lube up the holes in the bars to help the wires slide in and out easier as well.
Old Jun 15, 2009 | 08:57 AM
Zacharia_11's Avatar
Zacharia_11
Damn, the memories... I am contemplating a new set of bars but this thread has me 'reflecting' on the idea a little more... an afternoon of cussing, grinding, threading, cussing and for what! Well they do look a lot better run internally.
Old Jun 15, 2009 | 08:59 AM
Cheesecake's Avatar
Cheesecake
Quick tip... that I assumed everyone would know....
You run the bolt and string though before you install the bars....
If you tie a large washer on one end and the nut on the other you can move the bars around....
It also helps if you stagger the wire ends.... don't try and pull everything in one big clump..
I have done it with the bars on the bike... and with them on the kitchen table.....
IMO it was easier in the Kitchen
CC
Old Jun 15, 2009 | 09:27 AM
priceamp's Avatar
priceamp
Depending on the length of the bars, use 3 to 4 ft of 18g braided wire. Wrap the wire around the end of the wiring harness covering all the connector pins. Then wrap that end with black electrical tape do no connector pins are exposed. Then fish the wire through the bars starting at the grip location to the center of the bars. Pull the wire out. Then feed the wire harness through the bars by pulling on the fish line and pushing the wire harness through the bars. Best if done on the floor over carpet so you can use your feet to hold the bars still.
Old Jun 15, 2009 | 03:50 PM
RHillbilly's Avatar
RHillbilly
Originally Posted by refuzeandrezizt
It was a major PITA. My advise, LOTS and LOTS of dish soap. That ended up being the best thing for me. Good luck!!
Got them done today used the dish soap worked good thanks for all the suggestions
Old Jun 15, 2009 | 04:18 PM
refuzeandrezizt's Avatar
refuzeandrezizt
Good deal, glad it worked out for ya. Feels good once you get it done, but the process makes you wonder WTF to yourself. LOL
Old Jun 15, 2009 | 07:27 PM
wildman67's Avatar
wildman67
I sprayed mine with windex, and they pulled right through!
Old Jun 15, 2009 | 08:42 PM
wheely's Avatar
wheely
I used some TV cable and a slippery product called "Wire Ease". Didn't have any problems.
Old Jun 15, 2009 | 08:47 PM
refuzeandrezizt
My bars are 10" straight rise t-bars, let me tell ya, it was a BITCH. I would imagine it would be somewhat easier with apes, as they seem to usually have more curves instead of right angles. At least I hope that is the case, as I plan on putting some 14 or 16 inch apes on at some time or another.
JSager89
General Topics/Tech Tips
Nov 30, 2017 01:23 PM
Mike650
Apr 24, 2012 10:48 PM
DJ BNS
Apr 4, 2011 10:33 AM
N-gin
Mar 13, 2010 07:17 PM
57RebelRocker
Jan 13, 2009 07:57 PM
