Seriously Pi$$ed Off
Old Jun 16, 2009 | 09:45 AM
  #31
HBWill's Avatar
HBWill
Originally Posted by rbabos
That's the kicker here. Stock wheel has no problem and smooth to any speed I choose. I will post results of my findings whenever I find the cause.
Ron
Have you accurately balanced the wheel? You seem like a smart guy, and very proud to let us all bask in your glow, I might add.
Occam's razor my friend...
Old Jun 16, 2009 | 11:17 AM
  #32
DanDeuce's Avatar
DanDeuce
2K for a HD Blade , think you got screwed big time ! Hope you figure out your problem .
Old Jun 16, 2009 | 11:18 AM
  #33
Rabbit_'s Avatar
Rabbit_
I'd have the wheel balanced without the tire.
I'm with Citoriplus and HBWill, I don't think it's anything else other then the wheel and or rotor, especially when the problem goes away when you put the stock wheel back on.
Did the dealer mount the tire on the wheel? I'd get them to pull the tire off and run the wheel on the balancer without the rotor to see if the wheel is a fcuked, and then again with the rotor installed, just because it's new doesn't mean it can't be a dud.
If you dropped 2G's on the wheel I spend the couple of extra bucks to find out if you got a bad one and see if it can't be warrantied. Isn’t your dealer trying to help solve the problem after selling you a tire, install kit, and a $2000 dollar wheel??
I doubt you're the only guy to have the Blade installed on a FX front end, and if the motors harmonics are causing these problems then it would make sense that we'd be hearing about others having the same problems.
Old Jun 16, 2009 | 12:49 PM
  #34
mimo's Avatar
mimo
What???? $2K???? that is almost what I paid for my entire wheel set, tires, rotos, pulley and everything... You better dig deep to be sure it is not a defective wheel and/or a defective match up with your bike's model and the wheel, if the parts book says it fits you ride it better fit like a damn glove for $2K which I think is not all you've spent on that setup,
Good luck,
Mimo.
Old Jun 16, 2009 | 01:00 PM
  #35
frydaddy96's Avatar
frydaddy96
My .02, Did you check all the motor mounts for proper torque? I would think the extra mass of the new wheel would help to dampen the vibes. Since you know you have a bad crank, are you waiting for it to grenade the motor, why not get that fixed and see what happens. Like already mentioned, spin the wheel without the tire and maybe mount that tire to a known good wheel and see what happens. I'd also watch them do the balancing just to make sure it done right and not another of the famous " Thats normal" Good Luck
Old Jun 16, 2009 | 03:10 PM
  #36
rbabos's Avatar
rbabos
I live in Canada. Wheel, tire , install kit. Our dollar blows plus tax on top of tax. Still one of the cheaper billet models compared to others.
Ron
Old Jun 16, 2009 | 03:13 PM
  #37
rbabos's Avatar
rbabos
Yup. Dead nuts static. Done many a propeller in my day to so no mystery to the process. Thanks.
Ron
Old Jun 16, 2009 | 03:18 PM
  #38
rbabos's Avatar
rbabos
Dealer, are you serious? I used a static propeller fixture on knife edges and balanced with the rotor installed. The rotor runout is .003 and pads retract when lever is released. I agree there must be others out there without problems, so this is an exception for some reason as yet not determined. Being the stubborn bastard I am I will not give up that easy.
Ron
Old Jun 16, 2009 | 03:20 PM
  #39
mike06train's Avatar
mike06train
If the wheel is heavier, is it possible that the forks should get stiffer springs?
Old Jun 16, 2009 | 03:24 PM
  #40
rbabos's Avatar
rbabos
Good luck,
Mimo.
Why not stick a knife in my back while you are at it, as if I don't feel bad enough
This wheel lists everywhere at about 1150 is Us . Factor in the dif in Canadian funds, plus taxes. Customizing here is expensive.
Ron
