Seriously Pi$$ed Off
Old Jun 16, 2009 | 03:31 PM
  #41
juspasnthru's Avatar
juspasnthru
It's a shame that you can't adjust compression/rebound damping to see if that would have any affect-I wonder how much a different set of Fork Springs are?
Old Jun 16, 2009 | 07:43 PM
  #42
JR Ryder's Avatar
JR Ryder
Try a different tire on the NEW rim, and try the NEW tire (if you have one) on the old rim.
It sucks dude, and YES, I know all about the exchanges, duties, and taxes of pimpin'-out our rides up here in Canada eh?
I was just in London last week. Great riding down by Aylmer & Tillsonburg.
Hope you solve your problem there. I'll be keeping an eye on this post. JR
Old Jun 16, 2009 | 07:48 PM
  #43
rbabos's Avatar
rbabos
Solved the problem. This is a classic if you want it done right, do it all yourself.
Dealer who installed the tire was at fault.
Pulled the tire and found Dyna beads still in there even after he was suppose to remove them. He may have tried to some extent but the ton of soap and moisture in the air caused them to clump up. It always seem to shake more when the tire got warm on a longer ride. Here's my theory on how it plays out.
Tire shake is what positions these beads to the light spot, but with the FX front end and it's rake on the fxstc there is always some flexing and for and aft occilating going on from bumps and engine pulses vibrating the whole mess. Since the wheel is attached to this flexing shaking member it may be giving the beads faulse information on where to go, plus stuck together with soap won't help the effect much. Instead of balancing they did the opposite in this case.
Cleaned it all up, did a stick on treatment and drove around a bit to warm the tire up. Now for the acid test. Hit the super slab ran it at 80 90 and short 100 mph run. Back to normal now. While fork flex is and always will be there, it subsides right away instead of getting violent like when the clumped Dyna Beads were in there.
I have nothing against the beads as my 200 has them and no problem at all. For now the fixed weight stays. Anybody contemplating using Dyna beads needs to take care when mounting the tire in regards to soap, and water in the compressed air used. Life is good once again.
Ron
Old Jun 16, 2009 | 07:54 PM
  #44
mimo's Avatar
mimo
Kidding, glad the problem is solved... now ride those $2K in every road you can find!!!
Mimo.
Old Jun 16, 2009 | 07:57 PM
  #45
Six Gunner's Avatar
Six Gunner
Good to hear that you finally got to the bottom of your problem. Hope you didn't lose too much hair in the process. Wheel looks good by the way.
Old Jun 16, 2009 | 08:04 PM
  #46
rbabos's Avatar
rbabos
Can't tell, I'm almost bald now.
Ron
Old Jun 16, 2009 | 08:39 PM
  #47
Rabbit_'s Avatar
Rabbit_
Originally Posted by rbabos
Dealer, are you serious?
So what I'm hearing is you took it back to the Dealer and they found their ****-up and fixed it? Huh, who'd a thunk it...
Sarcasm aside, I glad it work out for ya.
Old Jun 16, 2009 | 08:59 PM
  #48
HugYourHog's Avatar
HugYourHog
Too bad you can't invoice the $tealership for all your lost time have to fix something they screwed up.
Bike looks nice with the blade, Ron. Glad you got it figured out.
Old Jun 16, 2009 | 09:45 PM
  #49
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Glad you found it was something stupid instead of some kind of bazaar design quirk.
Now lt's see a bigger pic of that wheel on the bike.
Old Jun 16, 2009 | 11:51 PM
  #50
JR Ryder's Avatar
JR Ryder
Glad you (or the dealer) figured it out. Man, you were pi$$ed. I don't blame you. I get all bent outta shape at this kinda stuff too. Bike looks awesome.
