lowering shocks vs lowering hardware?
Old May 20, 2006 | 07:45 PM
Softtail Bob's Avatar
Softtail Bob
Default RE: lowering shocks vs lowering hardware?
Is the Burnout kit made for pre 2000 year bikes? I have a 98 FXSTC and would be very intrested in this kit if it would work on my bike.
Old May 20, 2006 | 08:31 PM
pro1955's Avatar
pro1955
I have the Arlen Ness kit on my bike and it bottoms out over sharp edged bumps. Anyone have any idea if aftermarket shocks solve that problem?
Old May 20, 2006 | 08:53 PM
burnoutjeff's Avatar
burnoutjeff
6th Gear
Bob; We do not make anything for the pre 2000-different mounting.
Pro1955-anytime you lower the bike it will bottom easy and harsh-regardless of who's kit you use. The best thing you can do is try turning the preload up, all the way, try that it may help a bit.
Old May 20, 2006 | 09:42 PM
springerGT's Avatar
springerGT
When you you shorten the shocks with hardware you are shortening and preloading the shocks. What's that going to do for the ride? Hope you got a good back.
Old May 21, 2006 | 07:04 PM
burnoutjeff
6th Gear
Springer, Lowering kits for the softail do nothing to the spring preload, not our kit nor any others on the market.
The softail shocks work backwards from 'normal' shocks, in that they extend under a compression bump and compress during the rebound stroke.
The only thing effected with a softail lowering kit is the 'starting' point of where the shock stroke starts at.
The softail uses the frame/swingarm contact to control bottoming just like a car does. Typically we recommend increasing the spring preload when lowering a softail.
Old May 21, 2006 | 10:03 PM
jimb's Avatar
jimb
I used the ness kit.I made a shock press out of 3/8 all threaded rod, unistrut, and a floor flange.Worked out pretty good , couple of my buddy's used it also.
Old Mar 27, 2007 | 12:24 PM
kishstl's Avatar
kishstl
Great info Jeff thanks~!
Old Mar 27, 2007 | 01:41 PM
Kong's Avatar
Kong
I used the lowering extended bolts to do the rear of my Deuce. The extenders cost me $20 on E-Bay. Quality is not an issue with these things; they are probably on the order of 1,000 times as strong as they need to be, if not more. Instillation takes about an hour and a half if you've never done it before and have to make the "special tools" required to complete the job. By 'special tools' I mean whatever contraption you come up with to compress the shock to quickly disassemble and reassembleit. If you don't want to make one I think you'll find that the closest machine shop to your home will charge you $20 or lessto do it for you, if they charge you anything at all. You'd be simply amazed at how many guys working in, or sometimes owning, machine shops will cut a fellow Harley ower a break.
Removing and installing the shocks is easily accomplished without any special tools at all, despite what the Service Manual says about the rear bolt requiring some odd wrench. It doesn't, a plain old standard 3/4" box wrench works just fine.
With the extenders installed your stock shocks continue to give their stock ride, just a bit lower (or higher if you want). Ride height can thereafter be adjusted in about 5 minutes within a range of about +0.5 to -2.25. Its just a matter of jacking it up, loosening the lock nut, spinning the adjuster nut to wherever you want it, then retightening the lock nut and letting the bike down.
I had planned to go ahead and lower my front after doing the rear but to tell the truth there's no real reason to. I'mnot very tall (5' 8")so the lowering I did wasn't for looks, it was for comfort and control of the bike when at a rest. For me, a person who was reasonablysatisfied with the stock handling) the $20 extenders and the hour and a half it took to put them in was a lot smarter thing to go with than $700 shocks. The bike still rides just fine 2-up without bottoming out.
Old Mar 27, 2007 | 06:11 PM
hdpearson13's Avatar
hdpearson13
do front and rear do use white bros front they feel great an improvement over stock
bub 270
Apr 16, 2011 06:30 PM
Lorance66
Nov 24, 2008 03:55 AM
txroadking
Nov 6, 2008 06:20 PM
franki_22ca
Aug 29, 2008 11:46 AM
RamSportster
Jul 7, 2007 11:21 PM
