Go the gas route for now. Save the mechanical and chrome stuff for the off (winter/snow) season.
That way you don't miss any good weather riding days because the bike is apart in the garage.
I just took the K&N system off my bike for the heavy breather. It wasn't bad, just wanted a different look. It worked good but seemed expensive at $175.00 for a filter, back plate, breather extensions and small velocity stack.
I did it without help. It went on very easy. Just had a hard time getting the aft, upper, exhaust nut in place. I ended up using a pencil and a piece of putty, to get it on the threads. If the Fat cat had another 1/4" clearance, cutout in the heat shield, I would have been able to use my fingers to put the nut on.
Tom
Air shocks (I 'm not a small guy so this would keep from bottoming)
PCV (Everyone else seems to have one)
chrome chrome chrome (grips, switches, and everything else on the bars)
spend it on gas and ride ride ride
11 to 1 compression, big cams, ported heads and a good tune.
It will be just right then.
Oh ya....big apes. TALL ones.....makes the Heritage look badass.
