Embarassing question! (Foot peg removal)
Old May 25, 2006 | 12:38 PM
BrianK's Avatar
BrianK
Default Embarassing question! (Foot peg removal)
Okay, I'm a klutz, but I can't get the passenger's right-side footrest of my 06 Deuce. I replaced the exhaust system last night (V&H Pro Pipe - so far so good!) and want to get rid of the original muffler bracket. It's held on by two #50 Torx bolts (they came right off) and the footpeg. I turned the footpeg bolt counterclockwise to remove it; it loosened up but now just spins and spins without further loosening or coming off.
Anybody know how to get the #!@! thing off?
Thanks - BrianK
Old May 25, 2006 | 01:38 PM
BrianK's Avatar
BrianK
Default RE: Embarassing question! (Foot peg removal)
Anybody?
Old May 25, 2006 | 01:39 PM
oldude's Avatar
oldude
you have to take the foot peg apart at the male/female joint. There is an allen head bolt that goes into the bracket. I went to the local hardware store and got a shorter bolt to reassemble. HTH
Old May 25, 2006 | 01:40 PM
BrianK's Avatar
BrianK
Thanks oldude! - BrianK
06DEUCE's Avatar
06DEUCE
mine came off fairly easy. after i removed the nut just tap the bolt out....
[IMG]local://upfiles/4583/954D12EA939E43CB9427863A1BA45F9E.jpg[/IMG]
Old May 25, 2006 | 03:01 PM
Jezcruzen's Avatar
Jezcruzen
You removed the actual foot rest, right? Once that's removed, the footpeg mounting "stalk" (for lack of a better term right now) is attached to your frame with a #50 torx. (At least mine was) Problem is, the torx head is recessed down below the female fitting and a regular torx socket wont reach down that far. I had to have one made up for me that used a longer torx shaft in order for it to fit down into the female fitting and still seat into the torx head.
Old May 25, 2006 | 05:15 PM
BrookeWA's Avatar
BrookeWA
Yep, what he said...
ORIGINAL: oldude
Old May 26, 2006 | 03:33 PM
BrianK's Avatar
BrianK
Thanks all, you're exactly right. Now I just gotta find one of those long #50 Torx wrenches. Appreciate the help - BrianK
Old May 26, 2006 | 04:43 PM
ToBeFrank's Avatar
ToBeFrank
I loosened the bolt by turning the whole footpeg mount. Then I just used a big screwdriver in the torx bolt to remove it. Replaced the torx with a hex bolt. No #50 torx required.
Old May 26, 2006 | 05:29 PM
BrianK's Avatar
BrianK
Another good suggestion (screwdriver), I'll try that tonight - thanks - BrianK
