front and rear drop? Recommendations...
"Just got my Progressive Lowering kit in yesterday and tackled it at the shop last night. After rolling around the best way to get it in the air to get underneath it comfortably and work we came up with this. Worked like a champ. I'm 6'3", so it was bad *** to be able to get it up in the air high enough to walk under it. 2 4X4's, a forklift and some ratchet straps."
I'm going to take some pics of it at its new height tonight and show yall a good before and after. Looking back, this kit was really easy to install. I spent most of my time trying to come up with a way to compress the shock. After many attempts at different techniques I got a spring compression kit from the auto parts store. Squeezed it from both sides, the bottom hooking around the bottom of the cylinder, and the top hooking to a plate we made out of 1/2" AL that slid over the spindle far enough to make contact. I have my pre-load set to what the instructions called "lightest". I need to adjust it out to make the ride a little stiffer. It feels like stock now, just want to tighten it up a bit to prevent some bottoming out. I have a progressive 2" front drop planned for next week. I took the nut out to with in 3/8" from the end of the rod, this netted me just about 2", maybe a hair under. I love the way it feels, cant wait to get the front matching.
Question : When adjusting the pre-load for a stiffer ride, am I capturing the cylinder with the spanner, loosening the lock nut, and then running the next nut in towards the cylinder? As said above, I just bottomed it all out to the "lightest" to have a good starting point, but think that it needs to be tightened up a tad.
oh yea, lifting your baby 6 feet up in the air? ****ing nerve racking. I went over those ratchet straps 4 times, then once more before I put her in the air.
Before
After
I dunno about you and that forklift though...I though I was the American Psyco. You just stole my crown and set a new standard for badass figure it out on the fly ****!!
Now about them tall *** forks.....Can they even be considred for a little 2" progressive kit?
BTW...Your Standard is badass mang. I cant believe they discontinued that bike...Then again they just dropped the Train as well so go figure. We gots us some Co-Leck-Table Harleys now Bro!
Man the Limbo pole is getting lower and lower....Limbo-Limbo Jack be quick..Get yo' *** under that limbo stick!!
Limbo Edition....
Cant wait to see the front end join the *** in getting under that Limbo Pole!!
Funny you say as had I not bought a Train the standard was on my short list. Just a straight foward Harley canvas ready to be tweaked and fiddled with.
Thanks for the comps Mang!!
http://www.youtube.com/watch?v=hODEuJake_Q
