front and rear drop? Recommendations...
Old Aug 18, 2009 | 06:16 AM
  #31
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
Originally Posted by DarkTrak
Someone, anyone...tell me EXACTLY what I need to do to get the rear of my train as low as this guys!!! This bike is awesome!!
http://www.youtube.com/watch?v=hODEuJake_Q
Find a big handfull of moolah....Take said Moolah and purchase a quality Air Ride system.
Something like this :http://www.hotbikeweb.com/tech/0909_...all/index.html
Old Aug 18, 2009 | 07:48 AM
  #32
twisted125's Avatar
twisted125
It will be with me too, actually when the front goes on I'll be putting her back up to re-check the rear suspension and adjust the pre-load. Ill get some better pics next time shes sky high.
Here's a cool little fact, I think this is where the term limbo referring to ducking under a pole came from. We all know that limbo is supposed to be where you die but haven't transitioned, well the definition is actually - Limbo (Latin limbus, edge or boundary, referring to the "edge" of Hell) So apparently the lower you can go, the closer to hell you are. Pretty bad ***! Chaz man, limbo that train to the max and tell prince of darkness I said I'll see him in a bit.
Originally Posted by Chazmanian
Twist....The image of your Scoot up on that lift will live in my mind for quite some time.
Cant wait to see the front end join the *** in getting under that Limbo Pole!!
Funny you say as had I not bought a Train the standard was on my short list. Just a straight foward Harley canvas ready to be tweaked and fiddled with.
Thanks for the comps Mang!!
Old Aug 19, 2009 | 08:50 PM
  #33
david l nuttall's Avatar
david l nuttall
6th Gear
anyone lowered a roadking police 2007; they say just lower the rear but I think they're wrong ! and if you have can you do it by removing the nacelle and the fork bolts on top of the forks ? they told me you had to remove everything from the bottom, 5 to 6 hours of work
Old Aug 19, 2009 | 09:29 PM
  #34
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
(Spoken with heavy Asian accent....No offense to our fine Asian members!)
Hey you...Touring guy!! You go now!! We know nothing of what you speak. Sacriledge. Exposed shock under saddlebag. You go now to touring forum ask question.
LOL.... If I knew anything about Roas Kings or touring bikes I would help ya out...But als I'm clueless. I dont hardly know whats even behind them saddlebags.
Day-Um....I didnt know that. I dont generally name bikes and tend to look down on those who do ( J/K)
But I think I just found a new slogan!
Limbo Train!!
I'm gonna cut 3/4 off my 1.5" remaining PVC spacers this weekend. Gonna try for that little half inch and see if it works with my derned clutch cable....I'm addicted and cant stand how Gordon out Limboed me so easily!!
Old Aug 19, 2009 | 09:43 PM
  #35
raaaaaa's Avatar
raaaaaa
so no air suspension?
Old Aug 19, 2009 | 09:47 PM
  #36
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
I'm in this winter!
Which system are you running Raaaaa?
Old Aug 20, 2009 | 10:48 AM
  #37
twisted125's Avatar
twisted125
Ahhh, catchy . . . . Hmmmm, I'm due for tags reeeaaallll soon. Let us know how that PVC cut works out Chaz, I cant wait to make mine sit a little better.
Old Aug 20, 2009 | 10:54 AM
  #38
twisted125's Avatar
twisted125
oh yea . . . do you not hit your tag?? I looked at mine and it seems real close if I sit on it and bounce. I turned my wing nuts on the back side some to get their arm outa the way , about to get some lower profile nuts and see if it helps. I'm not really sure I wanna re locate my plate. Also, should we be paying any attention to the belt? Does it tighten up or get put into a bad bind? I still need to adjust my pre load, how tight is yours? I have mine set on the "lightest" setting, but need a bit more stiffness, especially when 2-up. Thanks in advance
Old Aug 20, 2009 | 02:38 PM
  #39
gimme's Avatar
gimme
yeah, I think this will be the first mod on my bike. it looks soo much cleaner. only sad thing is i think i regret getting black cherry/pearl. such nice bikes
Old Sep 8, 2009 | 05:01 AM
  #40
FREEFALL's Avatar
FREEFALL
Originally Posted by dkyork
I bought the Progressive front drop-ins as well. I believe I bought the 2" drop kit, so the PVC was 4.5" already. I just dropped them in. I did the rear 1.5-2" and it handles like a dream.
Dale
I just got my Drop in lowering kit and I'm kinda confused.
You say that you just dropped in the spacers as is 4.50"?
How much did it drop the front end?
The instruction sheet says that a longer spacer will raise the front end while a shorter spacer will lower the front end.
I want to drop the front end a full 2".
Do I need to cut the 4.5" spacer or just drop it in the way it is?
Thanks much for the help.
S/F
Freefall
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
